Point to point wireless connectivity
mansoor9349
Can I use Cisco AP 1240 for a point to point connectivity of 2 sites having a distance of approx 2 km
5 Replies 5
PaulGirard
mansoor9349, yes you can use the 1240 AP but I would suggest a high gain external patch antenna. I think at that distance your 802.11b interface will be available maybe even your 802.11a provided you have line of sight.
Do u suggest any antenna for that
I would suggest "AIR-ANT24120" antenna for 802.11G.
-> Sushil
The following Antenna suitable for your Requirement
AIR-ANT2410Y-R - 2.4 GHz,10 dBi Yagi with RP-TNC Connector
regs
S.Mohana sundaram
If it is outdoor use the following
AIR-BR1310G-A-K9 Aironet 1310 Outdoor AP/Br w/ Integrated Antenna, FCC Config
The integrated antenna will be sufficient for 2 KM Range
Rgds
Ganesan Velusamy
