Possible bricked 2602i
Tried to load 2602i with new firmware ap3g2-k9w8-xx.152-4.JB3 and since its loaded the Access point looks to be bricked its switches between Green and red light connected the AP to console and could see its being stuck here
*Dec 23 18:52:27.239: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
This is a standalone AP, so tried to restore it to default factory by holding the mode button , now i have a flashing red AP with
stuck configuration
Here's where i am stuck at
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP:  Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 50 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 13660160
flashfs[0]: Bytes available: 18337792
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 44:03:a7:a0:e6:5a
Ethernet speed is 100 Mb - FULL Duplex
button is pressed, wait for button to be released...
button pressed for 23 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
process_config_recovery: image recovery
image_recovery: Download default IOS tar image tftp://255.255.255.255/ap3g2-k9w7-tar.default
examining image...
DPAA Set for Independent Mode
DPAA_INIT = 0x0
%Error opening tftp://255.255.255.255/ap3g2-k9w7-tar.default (no such file or directory)ap:
Hall of Fame Super Silver
Re: Possible bricked 2602i
The image you used is a lightweight image which requires a WLC. If you wanted an autonomous AP you need the k9w7 image. The k9w8 is a lightweight image.
To understand the images, look at this link
https://supportforums.cisco.com/docs/DOC-19607
Now if you have loaded the wrong image, you can always load a different image. Here are other ways to perform this task.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
Just to add... Your AP isn't bricked. Make sure you check the MD5 hash on the image because if that is corrupt, the upload will fail. Here is a good link for ROMMON
https://supportforums.cisco.com/thread/2043235
-Scott
VIP Purple
Hi Ankur,
What you are trying to do is convert this Autonomous AP to Lightweight & then register it to a WLC then follow the below steps.
1. Download this (ap3g2-rcvk9w8-tar.152-4.JB3.tar) form Cisco
2. Rename your recovery image "ap3g2-rcvk9w8-tar.152-4.JB3.tar" as "ap3g2-k9w7-tar.default"
3. Configure your PC 10.0.0.2 with Mask 255.0.0.0 & GW 10.0.0.1 & put that image on a TFTP server running on that PC
4. Directly connect AP ethernet to your PC & power on the AP using power adapter while pressing the  MODE button
5. Release the mode button after 20-30s & monitor your AP console output
6. You should see AP loaded the recovery image from your TFTP server
If you are trying to upgrade the Autonomous Image then download the below image (ap3g2-k9w7-tar.152-4.JB3a.tar) & rename it as "ap3g2-k9w7-tar.default". Then follow the same process from step 3 onwards in the above.
Below post demonstrate this process & refer it for more detail
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful responses ****
Thanks everyone finally got the sytem to work had a hard time with tftp server timining out even after increasing the time out to 30sec. But now i am missing SSL certificate cannot use https to log in to gui any idea where can i find it or how do i restore it?
Check out page 44
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/12.4.25d.JA.cg.pdf#page44
-Scott
I already looked that up but the issue is i dont get the certificate warning all my pop up are enabled tried using maxthon and this is what i get.
Your AP is autonomous correct?
-Scott
Yes
Then wipe it... Try write erase and reload without saving. Might want to look at the flash and see if anything there you can delete.
-Scott
Can you post the show ver
-Scott
show ver
Cisco IOS Software, C3600 Software (AP3G2-K9W7-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 23:12 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SOFTWARE (fc1)
uptime is 21 hours, 42 minutes
System restarted at 17:36:51 -0800 Tue Jan 28 2014
System image file is "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-xx.152-4.JA1"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP2602I-A-K9 (PowerPC) processor (revision A0) with 180214K/81920K bytes of memory.
Processor board ID FGL1652Z83J
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 44:03:A7:A0:E6:5A
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16513ARN
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FGL1652Z83J
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP2602I-A-K9
Configuration register is 0xF
Okay... well if you wipe the AP you shouldn't have any issue with the cert.
config t
delete /force flash:config.txt
delete /force flash:private-multiple-fs
delete /force flash:private-config
erase nvram:
end
reload
This should clear up your AP.  Make sure that you clear out your cache on your browser just in case.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Will wiping the AP clear all the current config? since this AP was resetted to default factory setttings earlier.
It will clear everything... this was lightweight, so we are clearing that info also.  The issue you are having is with a certificate when you try to https, so unless the browser is caching it and giving you the error, then its best to clear out the AP.  factory reset doesn't clear everything out.
Scott
-Scott
That still didnt help.
So the only issue is when you try to use the GUI using https? Everything else works fine? You have tried to GUI in using a different machine?
-Scott
3 different machines and still the same result.
Your probably need to open a TAC case. Nothing else you can do especially if you already done what I have posted.
-Scott
Unfortunalely we dont have TAC support on our Access Points.
I was able to get the cert finally tried regenerating the self-signed certficate and it worked. Just in case if anyone needs more information and steps on how to do it follow the links below.
http://www.ciscozine.com/2012/05/25/how-to-create-self-signed-certificates/
http://www.skytale.net/blog/archives/37-Manually-converting-a-Cisco-AP-to-LAP-mode.html
Please find the symtomps below for the Red LED flashing.
Boot loader warnings - Red - Ethernet failure or image recovery (MODE button pushed for 20 to 30 seconds)
Boot loader errors - Red - DRAM memory test failure
Cisco IOS errors - Red - Software failure; try disconnecting and
reconnecting unit power
http://www.cisco.com/en/US/docs/wireless/access_point/2600/quick/guide/ap2600getstart.pdf
768
