power injectors don't work with APs
Has someone got experience on cisco power injectors for Aironet APs.
I bought 3 injectors, and 3 power supplys(injectors need power supply, but don't come with the boxes) from cisco.
I connected a switch(2960) port to the port ‘to network’ on the power injector, and connected a AP(1142N) Ethernet port to the port ‘to Device’ on the power injector.
The power injector was powered on by the DC supply. But the AP couldn't be powered on by the injector, and the switch port also showed 'noconnect'.
No particular commands setup on the switch port’s settings.  I tried the switch port auto-auto and 100-full, Vlan access and trunk, but no luck with the injectors.
Connected the same power supply to the same AP, used the same switch port and same cables, the AP worked fine with the switch.
Thought of faulty injector, but it's weird that all 3 new purchased injectors are faulty.
Am I doing anything wrong? do I need to put any commad on switch interface to use power injector?(I cannot believe that)  or just had bad luck of having 3 faulty injectors?
Please help.  Thanks a lot.
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
What kind of injectors do you have?  Take a photo and post it.  1140 will only take PWR-INJ4.
it's PWR-INJ3.  will it work with 1140?
No.
Damned to me.  Big Thank to you.
20W Single Port Midspan
Have a look at the link above.
Thanks for the ratings.
460
