01-11-2012 10:58 AM - edited 07-03-2021 09:21 PM
Are Cisco AP's vulnerable?
http://lifehacker.com/5873407/how-to-crack-a-wi+fi-networks-wpa-password-with-reaver
Is their a new IOS available to handle this?
01-11-2012 12:51 PM
If you mean a dictionary attack to crack your password, then yes. EVERY manufacturer is vulnerable. If you practice good choice of passwords, then it will take time for Reaver to punch through.
01-11-2012 01:04 PM
WPA and WPA2 "PSK" are susceptible to this issue. If an attacker captures the 1 and 2 or the 2 and 3 part of the 4 way handshake they can then use tools like COWPATTY or REAVER to crack against a dictionary.
What is important, dont use a KEY that will likely be in a dictionary.
01-11-2012 01:09 PM
So I can't use passwords like "password" or "youcantcrackthis" can I?
01-11-2012 01:11 PM
Follow the "rules":
1. Mix upper and lower case;
2. Use numbers;
3. Use common sense: Passwords like "love", "password", "admin", etc is the first few words to be tried by crackers.
01-11-2012 01:12 PM
Love, really ? Who uses "LOVE" ... Only Leo ...
01-11-2012 01:20 PM
ha ha ha
01-11-2012 01:22 PM
Too funny:)
Scott Fella
Sent from my iPhone
01-11-2012 03:47 PM
Leo must have been watching Hackers again!
To piggy back on George:
Cisco AP's do not use WPS, so they should not be vulnerable to this type of attack.
The Linksys side of the house however, can/does use WPS. you might want to hit the SMB forums and ask if they are aware of, and have a way to mitigate such attackes.
Steve
01-11-2012 04:15 PM
LOL!
01-11-2012 01:12 PM
BTW -- That program only cracks WPS, not WPA. WPS is used on home router wifi units.
here listen to this blog video
http://nostringsattachedshow.com/2012/01/08/e02-wi-fi-protected-setup-battered-or-broken/
05-17-2013 04:50 AM
You are partly right here George. Granted, Reaver 'only' cracks WPS PINs, but once it has done so you are 'given' the WPA/WPA2 PSK. In a round about way you are ultimately getting your goal, the WPA/WPA2 PSK.
A Reaver attack tutorial/demonstration using the OG150 is now available to download for free! WPA2 PSK WAS CRACKED IN 4 SECONDS!! Download the PDF tutorial from http://www.og150.com/tutorials.php.
Attack was demonstrated on a Linksys WAG54G2 router with v1.00.10 software.
Darren
05-17-2013 02:44 PM
As per your query i can suggest you the following solution-
Yes Ap's are vulnerable. You can use encryption, PSK,WPA.
Secure your SSID broadcast.
Mix characters and use numeric and alpha-numeric.
For more information you can refer to the link-
http://www.giac.org/paper/gsec/4094/securing-cisco-aironet-1200-access-point/106589
Hope this will help.
