Problem, configuring Wi-Fi in Cisco851W
I need to configure my Cisco851W, using WEP encryption with SSID, which anyone can find in wireless network neigborhood.(with Broadcast SSID in Beacon in terms of Cisco)
I am trying to do this simple thing using Wireless Application.
I input name of SSID,
then mark "Broadcast SSID in Beacon",
no VLAN
input IP address,
then mark Static WEP Key,
input Key
and after clicking apply, I see in the bottom of page my SSID with nothing in the column "Broadcast SSID"
And so, when I am trying to browse wireless networks near me with my notebook, I do not see this SSID.
Is it possible to do such thing with this router?
If the answer is yes, then
What I am doing wrong?
Could you please help me.
Thanks in advance.
Oleg
Below is my config
Re: Problem, configuring Wi-Fi in Cisco851W
Current configuration : 6415 bytes
version 12.4
no service pad
hostname Cek
boot-start-marker
boot-end-marker
no logging buffered
enable secret xxx
enable password XXX
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.100
ip dhcp pool HOME
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 192.168.1.1 217.10.32.5 217.10.35.5
ip dhcp pool wi-fiPool
import all
network 172.16.0.0 255.255.255.0
default-router 172.16.0.100
ip cef
ip domain name XXX.ru
crypto pki trustpoint TP-self-signed-1488117618
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1488117618
revocation-check none
rsakeypair TP-self-signed-1488117618
crypto pki certificate chain TP-self-signed-1488117618
certificate self-signed 01
30820242
quit
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ETH-WAN$
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly
speed auto
full-duplex
interface Virtual-Template1 type serial
ip unnumbered Vlan1
ip nat inside
interface Dot11Radio0
description Wi-Fi
ip address 172.16.0.100 255.255.255.0
no ip route-cache cef
no ip route-cache
broadcast-key change 600
encryption key 1 size 128bit 0 XXXXXXXXXXX transmit-key
encryption mode wep mandatory
encryption vlan 20 mode wep mandatory
ssid CiscoSec
speed basic-1.0 ...
station-role root
no dot11 extension aironet
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI1
ip address 172.16.1.100 255.255.255.0
ip nat inside
router rip
redistribute connected
network 10.0.0.0
network 192.168.1.0
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip nat inside source list 3 interface FastEthernet4 overload
ip nat inside source list 4 interface FastEthernet4 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.11.0 0.0.0.255
radius-server local
user XXXXX nthash 7 135747345E5B17071
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
speed 115200
line aux 0
line vty 0 4
access-class 103 in
privilege level 15
password qwerty
transport input telnet ssh
transport output ssh
scheduler max-task-time 5000
end
Hall of Fame Super Red
Hi Oleg,
Perhaps this is what you are looking for :)
The command that controls the "Broadcast" of the SSID is "guest mode". Have a look;
guest-mode (SSID configuration mode)
Use the guest-mode SSID configuration mode command to configure the radio interface (for the specified SSID) to support guest mode. Use the no form of the command to disable the guest mode.
[no] guest-mode
The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with the access point. It also allows clients configured without a SSID to associate.
Examples
This example shows how to set the wireless LAN for the specified SSID into guest mode:
(config-if-ssid)# guest-mode
This example shows how to reset the guest-mode parameter to default values (no broadcast SSID):
(config-if-ssid)# no guest-mode
From this IOS Command doc;
http://www.cisco.com/en/US/products/hw/routers/ps272/products_technical_reference_chapter09186a008022e0e3.html#wp2641711
Hope this helps!
Rob
Thanks a lot, Rob
you point me to the right direction.
Now I can see my SSID in wireless networks list, but I can not connect to it.
When i am trying to connect my notebook waits a couple of seconds, trying to connect and then says smth like that "can't connect to selected network. This network can be out of range. Try to refresh a list of available networks."
Do you have any ideas, how to solve this?
148
