Problem converting any AP to LAP - Cert not yet valid
All, I have a problem trying to convert APs to LAP.
I have the following scenario:
- 2 WLC 5508.
- For the WLC the image is 7.0.220.0
- 10 APs registered. 7 Cisco 1310 and 3 Cisco 1242.
- Time on the WLC indicates is July 4th 2013 - 19:20:00
I have 5 more APs ( Cisco 1231G and Cisco 1310) all of them are Autonomous.
Im using the Cisco upgrade tool, which I already use to convert the first 10 APs, and I have over and over the same problem, no matter if I use the Cisco 1231 or the Cisco 1310. Once I run the upgrade tool, in the middle of the process I had the following error on the AP:
*Mar  1 00:15:15.088: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 00:25:39.198: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:25:39 UTC Fri Mar 1 2002 to 00:25:39 UTC Fri Mar 1 2002, configured from console by moncl on vty0 (181.142.103.159).
*Mar  1 00:25:40.395: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:25:40.498: %SYS-5-CONFIG_I: Configured from console by moncl on vty0 (181.142.103.159)
*Mar  1 00:25:41.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jul  2 18:11:51.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:25:41 UTC Fri Mar 1 2002 to 18:11:51 UTC Tue Jul 2 2013, configured from console by moncl on vty0 (181.142.103.159).
Jul  2 18:13:22.641: %SSH-5-ENABLED: SSH 1.99 has been enabled
Jul  2 18:14:14.498: %SYS-5-CONFIG_I: Configured from console by moncl on vty0 (181.142.103.159)
%CRYPTO_PKI: CA Cert not yet valid or is expired -
    start date: 13:41:22 UTC Jul 31 2003
    end   date: 13:41:22 UTC Apr 29 2013
xa2arcbdepo02#
I tried setting manually the clock and also using the clock of the WLC, but with the same result.
I also tried to convert manually, but with the same result.
Also Im using c1310-rcvk9w8-tar.124-21a.JA2.tar and c1200-rcvk9w8-tar.124-21a.JA2.tar
Please, I really need your help because Im stuck with this problem!!.
Thank you all!!
Hall of Fame Super Gold
Post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh inventory; and
5.  AP:  sh ip interface brief
Re: Problem converting any AP to LAP - Cert not yet valid
Following the info:
(Cisco Controller) >show time
Time............................................. Wed Jul  4 19:48:12 2013
Timezone delta................................... 0:0
Timezone location................................ (GMT -3:00) Buenos Aires (Agentina)
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... WLC-EDASA_1
System Location.................................. Montecristo
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 181.142.123.23
Last Reset....................................... Power on reset
System Up Time................................... 4 days 7 hrs 14 mins 1 secs
System Timezone Location......................... (GMT -3:00) Buenos Aires (Agentina)
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... AR  - Argentina
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +43 C
External Temperature............................. +27 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 4
Number of Active Clients......................... 4
Burned-in MAC Address............................ 2C:54:2D:72:CE:80
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 50
xa2arcbdepo02#sh ver
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.3(7)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Fri 18-Nov-05 12:55 by ssearch
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.2(15)JA,  RELEASE SOFTWARE (fc1)
xa2arcbdepo02 uptime is 1 hour, 27 minutes
System image file is "flash:/c1310-k9w7-mx.123-7.JA2/c1310-k9w7-mx.123-7.JA2"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-BR1310G-A-K9-R   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FOC08420N5Z
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:43:85:54:12
Part Number                          : 73-8960-03
PCA Assembly Number                  : 800-24963-02
PCA Revision Number                  : A0
PCB Serial Number                    : FOC08420N5Z
Top Assembly Part Number             : 800-25292-01
Top Assembly Serial Number           : FTX0844U0EW
Top Revision Number                  : A0
Product/Model Number                 : AIR-BR1310G-A-K9-R
Configuration register is 0xF
xa2arcbdepo02#sh inventory
NAME: "BR1310", DESCR: "Cisco Aironet 1300 Series (IEEE 802.11g) Bridge"
PID: , VID: , SN: FTX0844U0EW
xa2arcbdepo02#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       181.142.123.11  YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
FastEthernet0              unassigned      YES NVRAM  up                    up
xa2arcbdepo02#
This IOS version does NOT look like a controller-based IOS.
Supporting Oversized Access Point Images
This is the Autonomous image. I dont say before but I also tried downgrading and upgrading the IOS of both, the Cisco 1231 and the Cisco 1310, but always had the same problem. The certificate is expired before I can use it, exactly 2 moths before the day I run the upgrade tool. More info, when I tried to upgrade to LAP using a manual method, the same problem appears with the same date ( 2 months from the day I run it)....
What I dont understand is that the first 10 APs were converted without any problem, with the same image, but now I cant...
What else should I check?
Please, help!
With what image should I try on the Autonomous AP to run the upgrade tool?
Try the latest one.
Hall of Fame Super Silver
Thank you Scott for the replay, but unfortunately I wasnt able to make this works!!
I downgrade the tool and also upgrade and downgrade the autonomous image, with no luck.
Also, changed the PC and the AP. Always with the same result.
When I use the upgrade tool, the result is the same, the certificate is two expired....
The first symptom I saw on the AP is that the tool updates the AP clock to one less than the actual hour. For example if I run the toll now (10AM), the tool update the clock of the AP to 9AM....
I already check the time of the PC and the time of the WLC and they both match exactly.
I used the two options available on the tool related to time (use the WLC time and use a predefined time) with the same result.
I guess that the only option is to manually update the AP, but unfortuntaly I dont know how to generate a base 64 certificate...
did you see another way to make it?. anything else to check or probe?.
I really your support.
VIP Purple
HI Jorge,
For the LWAP conversion, use the recovery image ( e.g  c1140-rcvk9w8-tar.124-25d.JAL.tar). We can use the command on the autonomous AP priviledge mode.
AP#archive download-sw /force-reload /overwrite tftp://10.10.10.1/c1140-rcvk9w8-tar.124-25d.JA.tar
Dont forget to rate helpful posts.
Same problem here with an AP 1121 and trying to upgrade under WCS
I would not try to use WCS but use the links to convert the AP.
-Scott
I'm having the same problem.. did someone get a solution? Any workaround?
What problem are you having..... what AP and what are you trying to do.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I'm trying to migrate a 1231. This is the debug I see in the AP:
ap#show clock
16:31:17.312 UTC Tue Dec 17 2013
ap#term mon
ap#
Dec 17 16:32:16.663: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 17 16:32:26.936: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 17 16:32:32.326: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 17 16:32:38.476: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 16 17:32:03.000: %SYS-6-CLOCKUPDATE: System clock has been updated from 16:32:40 UTC Tue Dec 17 2013 to 17:32:03 UTC Mon Dec 16 2013, configured from console by cisco on vty2 (147.83.194.126).
Dec 16 17:32:05.952: %SYS-6-CLOCKUPDATE: System clock has been updated from 17:32:05 UTC Mon Dec 16 2013 to 17:32:05 UTC Mon Dec 16 2013, configured from console by cisco on vty2 (147.83.194.126).
Dec 16 17:32:06.840: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 16 17:32:12.544: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 16 17:32:25.890: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 16 17:33:18.759: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)
Dec 16 17:33:47.811: %SYS-5-CONFIG_I: Configured from console by cisco on vty2 (147.83.194.126)%CRYPTO_PKI: CA Cert not yet valid or is expired -
ap#
ap#sho
ap#show clo
ap#show clock
17:34:44.152 UTC Mon Dec 16 2013
ap#
Dec 16 17:36:38.373: %SYS-5-CONFIG_I: Configured from console by cisco on vty3 (147.83.194.126)
And this is the output I see in the WCS:
START:     Detailed logging started at -> 12.17.2013_17.32.04 INFO:     TELNET to device 10.120.20.11 done. INFO:     Privilege level is equal to 15. INFO:     Setting vty line completed. INFO:     Dumped Environmental variables. INFO:     AP is supported for Upgrade process INFO:     IOS version is greater than or equal to 12.3(7)JA. INFO:     AP needs SSC to be installed INFO:     Device has supported radios. INFO:     Station role is root. INFO:     TELNET to controller 147.83.174.219 done. INFO:     SNTP server 1 147.83.2.206 INFO:     DNS and Domain name configured. INFO:     Mac address of device is 00:11:93:aa:b5:07 INFO:     Completed Dot11Radio0 shutting. INFO:     Device set up done and time configured on device. INFO:     Re-initialised SSC. INFO:     RSA Zeroize done. INFO:     Cleared trust point for SSC certificate. INFO:     Cleared trust point for Airespace new root certificate. INFO:     Cleared trust point for Airespace device root certificate. INFO:     Cleared trust point for Airespace Old root certificate. INFO:     Cleared trust point for Cisco root certificate. INFO:     Cleared trust point for Cisco Manufacture root certificate. INFO:     Generating RSA Keys this takes few mins... INFO:     Generated Self Signed Router Certificate. INFO:     Enable and display SSC. INFO:     Done profile enrollment for Cisco IOS. INFO:     Created trust point for Airespace new root certificate. INFO:     Created trust point for Aires. device root certificate. INFO:     Created trust point for Aires. Old root certificate. INFO:     Created trust point for Cisco root certificate. INFO:     Created trust point for Cisco manuf. root certificate. INFO:     Generated airespace-new-root-cert. ERROR:     10.120.20.11 Telnet/SSH session to the device failed. 1. Check reachability to the device. (OR) 2. Check Telnet/SSH is enabled on the device.
END:     Migration Process Failure: Telnet/SSH session to the device failed.
As you can see, int he WCS says that it can't connect.. but I think that the reason might be on the error that shows the AP about the certificate out of date (same problem than in the original post).
About the AP I'm trying to migrate:
Product/Model Number                 : AIR-AP1231G-E-K9
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JA2, RELEASE SOFTWARE (fc1)
If your ap configuration is large, prior to converting, you should erase the config and setup a telnet username and password. That is what I would try.
-Scott
I already did a reset do defaults.. so the config is actually minimal.
Then try using the LWAPP tool but you need XP or convert it manually. I never use WCS to do that.
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
-Scott
I had the same problem with an AP1121 when I was trying to migrate to LW with WCS, but I solved this migrating these aps with cisco LWAPP upgrade tool.
Here is a link to find out the SSC you need to add to the WLC.
https://www.cisco.com/public/technotes/smbsa/en/us/wireless/upgrd_auto_Aironet_acc_pts_lgtwt_mode.pdf
-Scott
Thanks for the information, but no way to use the WCS to do this conversion? It looks to me as just a matter of an outadated certificate somewhere.
We don't use Windows in our workstations and I'd need to setup a virtual machine just for this conversion. I find it a bit disappointing considering that we have the WCS for this sort of things.
No idea of which certificate should I update and how?
The way i did it, is to set the wlcs time to something before the cert expiration day.
It worked for me.
I think it would be nice, that at least the upgrade tool receives a new update with a new cert.
Time is always necessary when you want an AP to join the WLC. Older APs like the 1200's and 1230's that have a SSC can be a pain, but no matter how you try to convert these APs from autonomous to lightweight, the SSC can cause you issues if the tool your using doesn't import the SSC or if the time is off. Nothing else you can really do, but understand what you need to have done in order for the AP's to join. Other AP's don't have this issue, but the time still need to be correct for them to join.
I don't use WCS nor do I like the tool, but the upgrade tool does work. I prefer just to use the archive command to convert and then if there is an SSC, I would use the debug to discover the hash.
-Scott
Hi Scott,
the debugging is handy if you convert 1-5 APs with more you become insane.
I know that the 1200 and 1230er are "out of ebay" but i have many costumers with such old APs and they want to migrate to newer ones in little steps.
The upgrade tool is really helpful if you want to migrate a lot of APs.
I understand... A few months ago, I had to convert 200+ 1230's and I used the upgrade tool. I had to load XP on an old laptop to do the conversions. There were about 5 that we had to debug due to the tool not upgrading the AP properly.
-Scott
1977
