Problem with a Cisoc Aironet 1130AG
Brand new out of the box. I have used console cable to connect the device and logged in with the default Cisco priviledge password. Problem is it doesn't recognise the "configure terminal" command. I don't get that all Cisco devices have it. Below is my complete Privelege list of commands -
cd Change current directory
clear Reset functions
clock Manage the system clock
crypto Encryption related commands.
debug Debugging functions (see also 'undebug')
delete Delete a file
dir List files on a filesystem
disable Turn off privileged commands
enable Turn on privileged commands
exit Exit from the EXEC
fsck Fsck a filesystem
help Description of the interactive help system
led LED functions
lock Lock the terminal
login Log in as a particular user
logout Exit from the EXEC
lwapp lwapp exec commands
mkdir Create new directory
more Display the contents of a file
name-connection Name an existing network connection
no Disable debugging functions
ping Send echo messages
pwd Display current working directory
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
rmdir Remove existing directory
save Start to save raise_interrupt_level stack
send Send a message to other tty lines
set Set system parameter (not config)
show Show running system information
systat Display information about terminal lines
terminal Set terminal line parameters
test Test subsystems, memory, and interfaces
traceroute Trace route to destination
undebug Disable debugging functions (see also 'debug')
upgrade Upgrade software
verify Verify a file
where List active connections
Need help enabling the correct full list of commands.
Hall of Fame Super Silver
Re: Problem with a Cisoc Aironet 1130AG
That is because you have a lightweight access point. If you look at the model on the back of the ap, it probably says AIR-LAP1131. You should of gotten he AIR-AP1131. Just do a search to convert lwapp to autonomous on the cisco search or google. This will allow you to confiure the ap without a WLC which is required for a LAP.
-Scott
I haven't done it yet but I have just research your answer. You are 100% correct. You are a champ. Thank you.
No problem a lot of people purchase the wrong ap.
-Scott
Hall of Fame Super Gold
Converting LWAP to Autonomous Using the MODE Button and a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42lwap.html#wp1105224
Hope this helps you.
1083
