02-14-2012 03:43 AM - edited 07-03-2021 09:34 PM
Hi All,
Recently I have connected two AP AIR-LAP1142N-A-K9 to WLC 5508 via switch.
I can see both AP on WLC I can ping them but I would like to telnet or ssh to them but this does not work..
I am not fyzicaly at site and I have only remote access to WLC, switches ,, but not AP ...
Can you please advise?
02-14-2012 04:42 AM
To be able to telnet or ash to the aP you need to enable that from the WLC and set a username password first. Out of curiosity, since the AP are controlled by the WLC why do you want to access s the AP directly? You would only have limited ability to to pull some commands.
Steve
02-14-2012 04:54 AM
Thank you , those APs should be standalone.. I would like to have access for management purposes.
They have just installed them as they got them from cisco..
Do I have to change something on AP in order to have telnet or ssh acces?
02-14-2012 05:11 PM
I'm sorry, but can you clarify?
This means that you have a WLC but your WAPs are booting up in autonomous mode.
If you want access to them then let the WAPs get IP address dynamically and telnet/ssh into them. The username/password (by default) should be "Cisco/Cisco".
02-14-2012 05:27 PM
if you have them joined to your WLC you have the WLC for management.
Are you saying that tune should be IOS and not joined to your WLC?
Steve
02-15-2012 05:27 AM
Those two are stand alone access points , I can see them in WLC but I would like to telnet or ssh but it does not work
02-15-2012 06:17 AM
You don't manage the APs themselves, you manage them via the WLC if they are connected to one.
You can like Steve mentioned enable telnet or ssh for the APs via the WLC GUI but you can't do much on the APs.
02-16-2012 12:05 AM
Thank you , how can I enable telnet or ssh for the APs via the WLC GUI but you can't do much on the APs?
02-16-2012 01:24 PM
From the CLI of the WLC, the command is "config ap telnet enable
From the WLC GUI, go to Access Point Summary > All APs > Details > WAP of your choice > Advanced tab > Telnet or SSH.
