08-25-2012 03:44 AM - edited 07-03-2021 10:34 PM
Hi i have a cisco air lap 1522 but i have problem with it! I cant use config command in cli ? And i cant assign ip address to ap please help me! Tnx
08-25-2012 04:56 AM
You need a WLC for that AP to work.
Steve
08-25-2012 05:47 AM
Thanks for your response
I know but How i can access to wlc?
08-25-2012 05:57 AM
Sahar:
If you have WLC then if the AP in same subnet as management WLC IP address it will automatically discover the WLC.
You need a DHCP ip address to be active so that the AP gets an IP address.
If you don't have a DHCP server and you need to assign a static ip then use these commands:
AP#capwap ap ip addressAP#capwap ap ip default-gateway AP#capwap ap controller ip address
Reference: http://tiny.cc/1vkljw
note: use the word "lwapp" instead of "capwap" if "capwap" did not work.
Amjad
08-25-2012 05:58 AM
btw, you need to add a mac filter for the AP on the WLC to work.
check this: http://tiny.cc/5ykljw
08-25-2012 06:21 AM
My problem is that i dont have WLC?
08-25-2012 06:33 AM
You can't use that ap without a wlc. So you either need to return that or purchase at wlc.
08-25-2012 06:37 AM
Thanks alot for your response How i can purchase that? Is it software or hardware?
08-25-2012 12:55 PM
Please help me my friend i dont know what can i do with this device ?!!;(
08-25-2012 01:07 PM
Sahar: Who sold you this outdoor access point? Why did you get it if you don't exactly know how it can be used? shouldn't you know how to use it and what is needed to be bought with it before you get it? Without a controller this box you have is unusable.
Cisco wireless controller is a hardware that runs a software image. There are many falvors and the main difference is the number of access points that can be supported.
look here: http://www.cisco.com/en/US/products/ps6302/Products_Sub_Category_Home.html
Amjad
p.s: is it 1522 or 1252? confirm please.
08-25-2012 01:23 PM
Please dont be angry with me!!!;(
Nobody told me to tl bought it our company bought it! And i wanna to solve this problem!
İts 1522 !
So WLC is hardware! And how we can buy it? And although what is the price of WLC?
İ'm very sorry to ask this stupid question ! İ feel sad;( sorry
08-25-2012 01:40 PM
Don't be sad. We are trying to help you.
You can ask in your neighbor about any cisco dealer in your country and ask him about the controller prices.
08-25-2012 01:51 PM
Thanks alot for friends attentions!
the controller is seprate from ap? it means that the hardware device separate from ap?
08-25-2012 02:31 PM
Which WLC is suitable with this ap? Tnx
08-25-2012 03:28 PM
If you want to save some money, you can purchase a WLC2106 which is EOL. I you want something new and still supported, you can get a WLC2504.
