Problem with DHCP across 1242G (WGB role)
Most of my WGB systems utilze old (EOL/EOS) Aironet 340 product. All work just swell. I have started deploying the 1242G AP/WGB systems and have a configuration problem. When a DHCP tries to acquire an address (or release/renew WinXP/Win7) it fails. If I use a static client IP address it is OK.
My WGB config should be (or I want it to be) a transparent bridge - passing any traffic that the client generates seamlessly across the cat5 Ethernet and spitting it out to the Wireless connection - it's access point.
Has anyone solved this problem. I have deployed over 6 of these and all of the configs are generally the same. None allow a DHCP client to work.
Help!
Below is basic info (not the config at this point) about the hardware:
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Compiled Wed 16-Sep-09 19:06 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
System image file is "flash:/c1240-k9w7-mx.124-21a.JA1/c1240-k9w7-mx.124-21a.JA1"
Part Number                          : 73-13785-01
PCA Assembly Number                  : 800-37050-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1611361G
Top Assembly Part Number             : 800-29232-02
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1242AG-A-K9
Configuration register is 0xF
Re: Problem with DHCP across 1242G (WGB role)
Can you share the config if the 1242?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yes - here we go:
version 12.4
no service pad
service password-encryption
hostname badboy
enable secret
enable password
no aaa new-model
ip domain lookup source-interface FastEthernet0
ip domain name reallybigcompany.com
dot11 syslog
dot11 ssid TWD_ERP
   authentication open
   guest-mode
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 transmit-key
encryption mode wep mandatory
ssid AIREHEADE
antenna transmit right-a
antenna receive right-a
antenna gain 6
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0
station-role workgroup-bridge
arp timeout 300
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.12.1 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
exec-timeout 10800 0
line vty 0 4
timeout login response 60
password 7 121314151617181910
login
line vty 5 15
login
end
... nice weekend and vacation before that...
Anyway - this is a reproducible real problem. If I can find the answer to this, I have a couple of other issues with these 1242G AP/WGB configurations, but this problem with DHCP working across the connection is bad.
I know it's end of summer vacation time, schools starting... etc...
Anyone there? Hello... hello....... hllo........ hlo....... hl
I have dozens of WAPs and WGBs, but only these 1242G new ones are having this problem....
h e l p
What is upstream, an IOS AP or a WLC? The config looks fine, except personally I'd move away from WEP.
Steve
The upstream access points are all Cisco 1200. This specific problem is only happening when I have a newer 1242Gs as the work-group bridge. I use simple WEP because we still have about 1 dozen Aironet 350 series work group bridges. NO problems with DHCP from those attached clients (ack).
With this particular location (WGB), all the parents allowed are model AIR-AP1230B-A-K9. The same...
I have since changed a few configuration items - but it still exhibits the problem of the attached PC being unable to get a DHCP address. Another issue is from my mangagement PC on the same management IP subnet - I can't always ping it. Specifically I set the arp timeout to maximum. and the dot11 hold-off time to 5. Why age arps out at all because the attached clients (PC, Printer, etc) should never go down and I'm not worried about blocking a DOS where the hold-off time applies.
Here are the config additions (only):
dot11 ssid TWD_ERP
dot11 holdoff-time 5
ssid TWD_ERP
parent 1 000c.ceff.5061  <<-- AIR-AP1230B-A-K9
parent 2 000c.ceff.507d  <<-- AIR-AP1230B-A-K9
parent 3 000c.ceff.4d78  <<-- AIR-AP1230B-A-K9
parent 4 000c.ceff.4f7e   <<-- AIR-AP1230B-A-K9
arp timeout 2147483
987
