Problem with WIFI on 877w
Hi, I recently purchased Cisco 877w. I was trying to setup my Wifi connection but when I entered following commands:
int dot11 0
ssid WLAN
I entered SSID configuration mode. In Cisco 870 guide you have a lot of options you can do here but on my router (IOS version) I can's see any. When I type ? I can see:
When I used c870-advsecurityk9-mz.151-3.T.bin I received message: ssid configuration commands: exit  Exit from ssid sub mode
When I used c870-advipservicesk9-mz.124-24.T2.bin message was the same without exit option: ssid configuration commands:
Can someone tell me why I can't see any options ? Maybe I'm using incorrect IOS? Can someone point me in right direction?
Added on 27.11.2011
I just find out that function described in configuration guide:
authentication type
Example:
Router(config-if-ssid)# authentication open
Router(config-if-ssid)# authentication network-eap eap_methods
Router(config-if-ssid)# authentication key-management wpa
They are working and I can aply them but I still can't preview (using ?) what other options do I have. Does anybody know why this part is missing from IOS?
Message was edited by: Pawel Lenart
Everyone's tags (1)
1 ACCEPTED SOLUTION
This is deferred. Only in the old times you were configuring your SSID under the radio interface.
Try :
conf t
dot11 ssid
Cheers,
Nicolas
1 REPLY
Try :
conf t
dot11 ssid
Cheers,
Nicolas
873
