Problems with 1242ag initial config
Hello all.. i got a new aironet AIR-LAP-1242AG-E-K9 and i am been requested to configure it..
i'm having hard time doing it, since according to all the manuals and informations i found i should be able to easly do that trought web UI or CLI.
here some informations:
http is disable, so no Web UI
the "configure" command look to not exist, here what "?" show me:
AP001d.7095.4f62#?
Exec commands:
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade software
  verify           Verify a file
  where            List active connections
with no "configure" i stuck since i can do nothing!
other infos:
AP001d.7095.4f62#show version
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:44 by alnguyen
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
AP001d.7095.4f62 uptime is 43 minutes
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
cisco AIR-LAP1242AG-E-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FCZ123280SS
PowerPCElvis CPU at 266Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:70:95:4F:62
Part Number                          : 73-10256-07
PCA Assembly Number                  : 800-26918-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC122911LE
Top Assembly Part Number             : 800-29152-03
Top Assembly Serial Number           : FCZ123280SS
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-E-K9
Configuration register is 0xF
running-config is here: (no start is available)
AP001d.7095.4f62#show run
Building configuration...
Current configuration : 29653 bytes
version 12.3
no service pad
hostname AP001d.7095.4f62
enable secret 5 $1$ybi3$6Xx0BaRCQlN9rQnOv.YPL0
ip subnet-zero
power inline negotiation prestandard source
crypto pki trustpoint Cisco_IOS_MIC_cert
revocation-check none
rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint cisco-root-cert
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint airespace-new-root-cert
crypto pki trustpoint airespace-old-root-cert
crypto ca certificate chain Cisco_IOS_MIC_cert
certificate 5DC2D2980000001FF640
CERTIFICATES
interface FastEthernet0
ip address dhcp client-id FastEthernet0
no ip route-cache
duplex auto
speed auto
hold-queue 80 in
no cdp run
line con 0
line vty 0 4
login
transport input none
line vty 5 15
login
end
any idea on how i'm supposed to configure this AP?
thanks for help
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Problems with 1242ag initial config
You are running a controller-based IOS.
Converting from controller-based IOS to autonomous IOS is easy.  Just follow the link below:
Using a TFTP Server to Return to a Previous Release
Please don't forget to rate our useful posts.  Thanks.
1 REPLY
1609
