Pros and cons for one bridge with two ssid vs two bridge with one ssid per bridge
I am currently running three AIR-AP1232AG-A-K9, and have two SSID running.  The current Config is below, right it has two bridge, one for each SSID.  it was recommend to me that i would only need one bridge, however no real pros and cons were given.
what are the pros and cons to one bridge with two ssid vs two bridge with one ssid per bridge?
------------------ current running config ------------------
Building configuration...
Current configuration : 8332 bytes
! Last configuration change at 00:40:47 AZT Sun May 27 2012
version 12.3
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
service pt-vty-logging
service sequence-numbers
hostname ap2
logging count
logging rate-limit 512 except critical
logging console critical
enable secret 5 <removed>
clock timezone AZT -7
clock save interval 8
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip options drop
ip tcp synwait-time 10
no ip domain lookup
ip domain name jeremycrews.home
ip host rtwan.jeremycrews.home 192.168.16.1 192.168.16.33
ip host ap1.jeremycrews.home 192.168.16.2 192.168.16.34
ip host ap2.jeremycrews.home 192.168.16.3 192.168.16.35
ip host ap3.jeremycrews.home 192.168.16.4 192.168.16.36
ip host ooma.jeremycrews.home 192.168.16.5
ip host xbox.jeremycrews.home 192.168.16.6
ip host wii.jeremycrews.home 192.168.16.7
ip host ps3.jeremycrews.home 192.168.16.8
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip dhcp bootp ignore
ip ssh time-out 20
ip ssh authentication-retries 2
ip ssh version 2
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting update periodic 60
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 syslog
dot11 ssid guestonpg
   vlan 2
   authentication open
   authentication key-management wpa optional
   guest-mode
   wpa-psk ascii 7 101F5F415730070E1F10
   information-element ssidl advertisement
dot11 ssid playground
   vlan 1
   authentication open
   wpa-psk ascii 7 0652577119195E41574441
dot11 holdoff-time 60
dot11 ids eap attempts 3 period 60
dot11 network-map
dot1x timeout reauth-period server
username <removed> privilege 15 secret 5 <removed>
archive
log config
  logging enable
  logging size 255
  notify syslog
  hidekeys
path tftp://192.168.16.12/ap2-config
write-memory
time-period 10080
bridge irb
interface Null0
no ip unreachables
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Dot11Radio0
description Radio b/g
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip wep128
encryption vlan 2 mode ciphers aes-ccm tkip wep128
broadcast-key vlan 1 change 3600 membership-termination capability-change
broadcast-key vlan 2 change 3600 membership-termination capability-change
ssid guestonpg
ssid playground
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
mobile station period 20 threshold 70
beacon privacy guest-mode
l2-filter bridge-group-acl
interface Dot11Radio0.1
description Home WLAN b/g
encapsulation dot1Q 1 native
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
ip access-group guestAccess in
ip access-group guestAccess out
no ip proxy-arp
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 port-protected
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
description Radio a
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ssid guestonpg
ssid playground
dfs band 3 block
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel dfs
station-role root
rts threshold 2312
infrastructure-client
interface Dot11Radio1.1
description Home WLAN a
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
bridge-group 1
interface Dot11Radio1.2
description Guest WLAN a
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
bridge-group 2
interface FastEthernet0
description RTWAN 192.168.16.1 192.168.16.33
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
description Home LAN Fa
ip helper-address 192.168.16.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
description Guest LAN Fa
ip helper-address 192.168.16.33
no ip route-cache
bridge-group 2
interface BVI1
description Home Bridge LAN to WLAN
ip address 192.168.16.3 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface BVI2
description Guest Bridge LAN to WLAN
ip address 192.168.16.35 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip default-gateway 192.168.16.1
no ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
ip access-list extended guestAccess
permit tcp any any established
permit tcp any any eq www
permit udp any any eq bootps
permit udp any any eq bootpc
deny   ip any any
access-list 22 permit 192.168.16.0 0.0.0.63
snmp-server community <removed> RW 22
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps cpu threshold
snmp-server enable traps aaa_server
snmp-server host 192.168.16.10 <removed>
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.16.1 auth-port 1645 acct-port 1646 key 7 <removed>
radius-server vsa send accounting
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
line con 0
password 7 <removed>
logging synchronous
transport output ssh
line vty 0 4
logging synchronous
transport preferred ssh
line vty 5 15
logging synchronous
scheduler allocate 4000 1000
scheduler interval 500
process cpu threshold type total rising 80 interval 10 falling 40 interval 10
sntp server 192.168.16.1
sntp broadcast client
end
1 ACCEPTED SOLUTION
Bronze
Hi Jeremy,
The access point only supports to have one BVI1 interfaced configured with an IP address since it is a basic layer 2 device.
Since it is IOS based you can try to configure an Ip address to more then one BVI1 but this will not work since the AP only supports an IP address configured on the BVI1 interface for managment of the unit.
Know the access point allows us to configure VLANs and for VLANS to work we need to link each VLAN to an specifc bridge group leaving always the bridge group one that is linked to the BVI1 for the VLAN the access point has an IP address of and set as native VLAN.
Here is the link that explains how VLANs work on the access points.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml
If you work with VLANs you can have different subnets or VLANs linked to each SSID and each SSID with an specifc security method.
Bronze
Hi ,
I review the confguration and both show configured as access points and not bridges.
When we work with 1 SSID it is becasue you have one flat network and the network devices and wireless clients are on the same subnet or VLAN.
When we work with more then 1 SSID it is becasue you have segmented your network on to VLANS, for example managment VLAN, guest VLAN, user VLAN ,etc. So for each VLAN you create and SSID and link to the correct VLAN and then with the specifc Security method per WLAN.
      Interesting, what i mean by bridge is nto bridge mode by have two BVI interfaces.  So here a better idea are the any pros and cons to running two ssid thruogh the same bridge group?
Bronze
Hi Jeremy,
1404
