01-14-2014 10:18 AM - edited 07-04-2021 11:57 PM
Hi, I am trying to set ip address on cisco ap AIR-LAP1252G-A-K9 using the "lwapp" command but get message "command is disabled"
I am connecting via console cable to ap. I have already reset ap to defaults.
Not sure why I'm getting this error "command disabled" Any help would be much appreciated. Thanks
01-14-2014 10:20 AM
You need to erase the nvram.
Entered the username and password
debug capwap console cli
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
01-14-2014 10:36 AM
Hi Scott, I dont see "capwap" as an option on the ap. The ap is not connected to the controller at the moment. Here is some more info. When I first connected ap to controller I could not get the ap to join the controller and set it's static ip. So I disconnected ap from controller. I am now trying to set static ip on the unconfigured ap but get the message "command disabled" for all write commands.
01-14-2014 10:48 AM
Replace the capwap keyword with lwapp in that situation.
01-14-2014 11:53 AM
This is a hidden command so don't try using a ? Since your ap is a 1252, like Rasika mentioned, use lawapp instead of capwap.... you need to erase the nvram.
The other way is this method:
ap:delete flash:private-config
ap:delete flash:private-multiple-fs
ap:boot
Your AP will be factory default
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-14-2014 10:47 AM
Does your AP already regiser to a WLC ? In that situation that error msg is expected.
If you want to forget any previously know WLC & start from fresh, follow what Scott's advise.
Below post may be useful as well. sometime replace lwapp keyword with capwap if your AP has latest recovery image which no longer supports lwapp
http://wirelessccie.blogspot.com.au/2009/08/configure-your-lwapp-ap-from-ap-cli.html
Rasika
**** Pls rate all useful responses ****
01-14-2014 10:54 AM
Hi the WLC is in production and using 3 Ap's. I am trying to add the 4th one.
01-14-2014 11:02 AM
ok, do this & get the AP console output when it is trying to register to your WLC again. What is the WLC software code you are running & what model WLC is it ?
debug lwapp console cli
write default
reload
Based on the console output after this point, we can tell you what to do
Rasika
01-14-2014 01:13 PM
Hi, not sure what happen but the AP is now regestering with the WLC and I am able to configure, seems to be working so far.
It may have been the resset. Anyways thanks for your help
