Radio 0 is not present in cisco 1142 AP
Hi all,
In one of our cisco 1142 AP , the 2.4Ghz is not seen . During bootup I can see like "Radio 0 is not prsent ". The other AP's are working fine.
The show version is ,
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 10:20 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1)
AAT-BLR-AP-04 uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w7-mx.124-21a.JY/c1140-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1142N-N-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
1 Gigabit Ethernet interface
1 802.11 Radio(s)
Please suggest
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Radio 0 is not present in cisco 1142 AP
Vijay,
Changing image and or the boot loader will not fix a radio that isn't being detected. That output is what you see when a radio goes bad. Some AP's last a long time, others don't.
-Scott
Even I tried to upgrade the AP with
c1140-k9w7-tar.124-25d.JA2.tar  , but still it didnt detect the radio 0 . Can I consider this an defective unit?
VIP Purple
HI Vijay,
Try the following:
1.  Console into the AP and post the complete "sh log".
2.  Reload the AP.
did u connected this AP to a switch ?? If yes then can u connect another AP to same port on swicth and see if this AP shoes the 2 radio or not ??
If either fails then it probably is a bad radio in the slot,
I would suggest opening a warranty claim on the unit and replacing it. or raise a tAC case.
Hope it helps.
Reagrds
Dont forget to rate helpful posts
The radio went bad... You will need to RMA it if you have support.
-Scott
All other Ap's are having bootloader version of
12.4(23c)JA3 , whereas this AP is having
12.4(23c)JA1. And I am not able to find 12.4(23c)JA1 download page , for upgrading in this AP to sort out bootloader version is not the source of issue for this.
VIP Purple
Hi Sandeep ,
Even I have seen the same only in the download page . But two of other AP is having the bootloader image of  12.4(23c)JA3 . How come it is possible ? Any idea..
Thanks..
VIP Purple
Hi Vijay,
I am not aware if this is comaptible with 1140 AP or not but this iamge is here:
This is the image for LAP.
http://software.cisco.com/download/release.html?mdfid=283307702&flowid=16363&softwareid=280775090&release=15.2.4-JB3&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Vijay,
-Scott
Thanks a lot Mr.Scott for the clarification.. I will look for RMA for thesame
159
