Radio G being recognized as Radio B
I have a wireless controller 5508 with a few 1240 AP's connected. AP's are set up as flexconnect both local switching and local authentication. Clients connected to the AP's are displayed using radio b instead of radio g on the controller. Connection speed and data rates confirms they are using radio G. If I set the APs to local switching and central authentication the radio displays correctly on the controller. I've been doing a lot of research and cannot find anything regarding this issue. Is this a bug or am I missing a configuration somewhere?
My AP software version is 7.5.102.0, boot version 12.4.13.0, IOS version 12.4(25e)Jan1, and mini IOS version 3.0.51.0.
Any thoughts would be greatly appreciated. Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Radio G being recognized as Radio B
Well one of the reasons maybe is the fact that you are using 1240's. I don't see many 1240's in any of my installs and typically I'm replacing these with newer access points. Could just be an issue with that model of AP as I don't see that with any other 802.11n AP.
-Scott
It seems to be a bug.
Hall of Fame Super Gold
Post the command output of "sh client detail ".
(Cisco Controller) >show client detail 24:77:03:0d:09:b8
Client MAC Address............................... 24:77:03:0d:09:b8
Client Username ................................. host/somthing.com
AP MAC Address................................... 00:3a:9a:18:59:80
AP Name.......................................... ABC
AP radio slot Id................................. 0
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 00:3a:9a:18:59:80
Connected For ................................... 24625 secs
Channel.......................................... 1
IP Address....................................... 172.3.2.1
Gateway Address.................................. 172.3.2.5
Netmask.......................................... 255.255.255.0
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... 4
Client E2E version............................... No E2E support
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Disabled
Power Save....................................... OFF
Current Rate..................................... 54.0
Supported Rates..................................
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. none
AAA Role Type.................................... none
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
Client Type...................................... SimpleIP
mDNS Status...................................... Disabled
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... 802.1x
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... PEAP
FlexConnect Data Switching....................... Local
FlexConnect Dhcp Status.......................... Local
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Local
Quarantine VLAN.................................. 0
Access VLAN...................................... 120
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Not implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 0
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 403662
      Number of Bytes Sent....................... 238499
      Number of Packets Received................. 4917
      Number of Packets Sent..................... 2602
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 214
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 5874
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -68 dBm
      Signal to Noise Ratio...................... 27 dB
Nearby AP Statistics:
      WDMFG-1242-44(slot 0)
        antenna0: 47 secs ago.................... -96 dBm
        antenna1: 47 secs ago.................... -86 dBm
      WDMFG-1242-47(slot 0)
        antenna0: 47 secs ago.................... -78 dBm
      WDMFG-1242-46(slot 0)
        antenna0: 47 secs ago.................... -89 dBm
        antenna1: 47 secs ago.................... -92 dBm
      WDMFG-1242-52(slot 0)
        antenna0: 47 secs ago.................... -81 dBm
        antenna1: 47 secs ago.................... -85 dBm
      WDMFG-1242-45(slot 0)
        antenna0: 47 secs ago.................... -68 dBm
        antenna1: 47 secs ago.................... -65 dBm
      WDMFG-1242-49(slot 0)
        antenna0: 48 secs ago.................... -93 dBm
DNS Server details:
      DNS server IP ............................. 172.3.2.205
      DNS server IP ............................. 172.3.2.204
Assisted Roaming Prediction List details:
Client Dhcp Required:     False
Might be a bug on the GUI for that AP model... from your post, they are connected at OFDM rates:
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Agree with Scott.  The command output shows 54.0 Mbps rate.  So it should be 802.11g.
But wait, there's more ... Look at the line below, "Supported Rates", it's blank.
For failed to disclose the wireless card brand/model.  I hope it's not an Intel N.
What is an Intel N?
But with an AP that is authenticated centrally it displays the supported rates:
Current Rate..................................... 48.0
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
What is the wireless card of the client?
You can also look at the rate the client device is connected to. 802.11b is limited up to 11mbps with rates of 1, 2, 5.5 and 11. If you see anything higher rates you are using 802.11g
-Scott
Scott,
Have you seen that bit where you have a value at "Current Rate" but nothing on "Supported Rates"?  I haven't.
Leo,
I have not and I play around with data rates like there is no tomorrow. Whatever I have enabled is the only rates I have seen clients negotiate at.
-Scott
Thank you all for replying.
I have checked the client and the client is showing the correct speed (G). As long as it's getting the correct speed I'm fine, it's just that it would be nice to report something back to my boss, i.e. a bug, or something being worked on, or it's normal, etc. I'm just surprise that no one else is seeing this.
-Scott
Yah I know the AP models are older, we're hoping to get newer ones in the near future. But for now, I'll just blame it on the 1240's.
I would:).... If you really want to dig in more, maybe open a TAC case and see what they say. Hopefully they don't just say upgrade your WLC code:)
-Scott
Cool Scott.
284
