03-04-2012 07:46 AM - edited 07-03-2021 09:43 PM
Does anyone know if there is a way to automatically enable/disable either the radios or the authentication for an ssid on a wlc? I'd want to disable at night and re-enable in the morning based on a time schedule.
Solved! Go to Solution.
03-04-2012 01:23 PM
You have three options:
1. WCS (as George has mentioned);
2. EnergyWise (as Scott has mentioned); and
3. Time-based ACL.
03-04-2012 08:13 AM
Yes, if you have WCS create a template to enable and disable the WLANs. Then schedule the template at the times you want.
03-04-2012 09:22 AM
Just to add to George's post... seems like this come up once a month:) If your doing 802.1x, you can also set a time for authentication, but the radios will still be on. If you have switches that support energy-wise, you can shut the port off and on also at a certain time.
03-04-2012 09:54 AM
I'll check into the energy wise configs. The switches we have are virtually brand new 2960s.
03-04-2012 09:53 AM
I'm afraid I don't have wcs.
03-04-2012 01:23 PM
3. Time-based ACL.
03-04-2012 06:21 PM
acl looks like it might be easiest. Thanks.
03-04-2012 06:29 PM
