Radio Signal Diagram - CAP1602I
Hellooo,
i will be having the:
WLC: AIR-CT2504-50-K9 and having another WLC for HA
and
AP: CAP1602I
what i am concern of is the signal diagram, or the broadcast diagram for this access point?
how the AP signal will be Distributed around here,will it be a circle or in which shape ?
Hall of Fame Super Silver
Re: Radio Signal Diagram - CAP1602I
Signal varies depending on attenuation from objects in its path. There is no real shape you can compare the signal coverage to. A site survey using a tool can capture signals and show you the signal coverage pattern.
In an open field with nothing around, the signal will propagate in a circle. Once you start putting object in, them that theory goes away.
-Scott
what i want is will the signal shape be like ths or what is the real broadcast shape:
i hope i deliviring the info correctly.
The AP is an omni, so the signal will propagate in a circle.
-Scott
Thank you,
but what is the recommended distance from the client and the AP
and the recommended distance from an AP and the other AP
Client to ap depends on what applicant .. Data = 75 dBm voice = 67 dBm (edge) also keep in mind this is assuming an accurate link budget
Ap to ap in same channel you need a minimum of 20 dBm
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
can we convert the dBm values to distance in meters
If you whisper something and I say I heard it at -90 dBm and then you yell at me and I say I heard you at -50 dBm .. All depends on how loud your ap is tx, antenna gain, and antinuation
You can... sort of.
Your RSSI is a measure of how much "volume" is lost, as in George's example. This gives you the basis of how to lab this out and get your own readings.
Lab this out in a relatively open area, eg auditorium, lobby, etc... or better yet on site. Set up the AP, take your most representative client device and--if the client device doesn't show signal strength in RSSI--a smartphone with a wifi app that shows RSSI (there are abundant examples).
Step one meter away, refresh smartphone RSSI readout, run standard operations representative of daily operations with the client device. Document your findings as to distance, RSSI, and acceptability of client device operations.
Repeat until you find where your client device is unacceptable. This should give you a baseline understanding of ROUGHLY what to expect. You will have different interference patterns from client devices, APs, microwaves, physical obstructions, etc etc etc. Use these as your numbers, and ensure anyone who sees your distance chart understands it is NOT 100% accurate in all situations, just a rough guess to help you decide how far is too far from the AP.
Technically it will NOT tell you how far is close enough to the AP! This is due to all the possible interferences and variances... but it can help you plan a whole lot better.
There are planners you can use to guess on coverage. Always best to do an active survey ..
397
