random disconnection problems with 5 Aironet 1142 same building
We have 5 pcs Cisco Aironet 1142  Access Points without controller at the same building. SSID is same for all of them. Our problem is client connected via wireless disconnecting randomly and continues working after a few seconds. IOS versions are same for all of them you can find detailed information about versions and configurations below. Please check configs and help about our mistake or give us advise about how to fix this issue.
Thanks and regards
Kamer AKIN
Sh ver outputs are same for all ap's
alt-gsa-cisco-ap-231-1#sh ver
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(25d)JA, RELEASE        SOFTWARE (fc1)
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE        (fc3)
alt-gsa-cisco-ap-231-1 uptime is 16 weeks, 31 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w7-mx.124-25d.JA/c1140-k9w7-mx.124-25d.JA"
cisco AIR-AP1142N-E-K9     (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1504W8PL
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from reload
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:3D:E5:93:2D:21
Part Number                          : 73-12836-01
PCA Assembly Number                  : 800-33767-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC15017S4U
Top Assembly Part Number             : 800-33775-01
Top Assembly Serial Number           : FCZ1504W8PL
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1142N-E-K9
Configuration register is 0xF
sh run outputs are same for each ap.also all running config copies are attached.
alt-gsa-cisco-ap-231-1#sh run
Building configuration...
Current configuration : 1805 bytes
version 12.4
no service pad
service password-encryption
hostname alt-gsa-cisco-ap-231-1
logging rate-limit console 9
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
ip domain name gold.local
dot11 syslog
dot11 ssid gsawlan
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 XXXXXXXXXXXXXXXXXXXX
username Cisco password 7 XXXXXXX
username admin privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid gsawlan
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid gsawlan
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.172.15.231 255.255.255.0
no ip route-cache
ip default-gateway 10.172.15.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: random disconnection problems with 5 Aironet 1142 same buil
Well if you are using WPA2 you should be using AES not TKIP. Use TKIP if your doing WPA. Don't use both WPA and WPA2 on the same SSID either. I would also maybe hard set your channels on each AP.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Its funny you mention all the info about the AP. But what about yout clients ?Most disconnects are cleints related, did you know that ?
What clients and NICs you useing ?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
We changed TKIP to AES at all ap's. Connection problems resumes We have different kinds of notebooks (atheros, broadcom, intel) Do you have any idea for configuration to increase compatibility ?
BR
Kamer
If you disable 4 AP's and have only one AP running, does the problem happen?
I have another office working with one ap and same config. Its working just fine.
Since this office has issues can you shut down 4 AP's and enable one only to do a test?
1198
