RAP Running flex+bridge back haul A radio will not turn on
Hardware: WLC 5508 running latest Software Version 8.0.100.0
AP Code : c1550-k9w8-xx.153-3.JA
Description :Whilst running in flex+bridge mode and configured as a Root AP, the RAP back-haul A radio will not change to operationally UP.
If the AP is changed to be configured as a MAP, the A radio back haul will go operationally UP.
Debug of the AP below and screenshot of the WLC has been attached.
flashfs[0]: 38 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 10195456
flashfs[0]: Bytes available: 21673472
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: b0:00:b4:61:a2:20
Loading "flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-mx.153-3.JA"...############
File "flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-mx.153-3.JA" uncompressed and installed, entry point: 0x3000
executing...
IOS Secondary Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: flashfs fsck took 5 seconds.
Boot CMD: 'boot  flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-xx.153-3.JA;flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-xx.153-3.JA'
Loading "flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-xx.153-3.JA"...################################
File "flash:/c1550-k9w8-mx.153-3.JA/c1550-k9w8-xx.153-3.JA" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1550 Software (C1520-K9W8-M), Version 15.3(3)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 15-Aug-14 13:50 by prod_rel_team
Initializing flashfs...
flashfs[2]: 38 files, 3 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31610880
flashfs[2]: Bytes used: 10195456
flashfs[2]: Bytes available: 21415424
flashfs[2]: flashfs fsck took 6 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 5806080
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 5805056
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Radio0  present 8364B 8000 A8020000 0 A8030000 30
Rate table has 336 entries (20 legacy/64 11n/252 11ac)
POWER TABLE FILENAME = flash:/c1550-k9w8-mx.153-3.JA/J2.bin
Radio1  present 8364B 8000 B8020000 0 B8030000 13
POWER TABLE FILENAME = flash:/c1550-k9w8-mx.153-3.JA/J5.bin
Radio2 not present 0 0 0 0 0 11
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1552EU-N-K9 (PowerPC 8349) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1824P030
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from unknown reload cause - ptr to non-ascii bytes 0x17
LWAPP image version 8.0.100.0
4 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: B0:00:B4:61:A2:20
Part Number                          : 73-13538-02
PCA Assembly Number                  : 800-31224-01
PCA Revision Number                  : 03
PCB Serial Number                    : FOC18159782
Top Assembly Part Number             : 800-38848-03
Top Assembly Serial Number           : FTX1824P030
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1552EU-N-K9
% Please define a domain-name first.
Spanning Tree protocol for Bridge Group 1 has not been configured.
Press RETURN to get started!
*Mar  1 00:00:08.551: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:09.311: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-6)
*Mar  1 00:00:09.311: Registering HW DTLS
*Mar  1 00:00:09.751: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:11.547: %LINK-6-UPDOWN: Interface Ethernet4, changed state to up
*Mar  1 00:00:12.415: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:12.423: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.423: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:12.423: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:12.423: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:15.279: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:15.471: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:15.535: Starting Ethernet promiscuous mode
*Mar  1 00:00:18.103: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:18.103: %SNMP-5-COLDSTART: SNMP agent on host APb000.b461.a220 is undergoing a cold start
*Mar  1 00:00:19.443: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:20.019: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source
*Mar  1 00:00:20.323: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
*Mar  1 00:00:21.503: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:22.151: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:22.191: Starting Ethernet promiscuous mode
*Mar  1 00:00:22.355: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:22.355: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:36.591: Currently running a Release Image
*Mar  1 00:00:36.603: Using SHA-1 signed certificate for image signing validation.
*Mar  1 00:00:41.019: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:00:41.023: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:41.031: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 CLI Request Triggered
*Mar  1 00:00:41.035: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:42.115: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
Not in Bound state.
*Mar  1 00:00:42.123: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:43.031: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:43.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:43.223: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:44.223: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:46.067: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.067: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:46.103: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.199.119.144, mask 255.255.255.192, hostname APb000.b461.a220
*Mar  1 00:00:46.103: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.103: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:51.143: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:51.211: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
Translating "CISCO-CAPWAP-CONTROLLER.bla"...domain server (10.207.15.11)
*Mar  1 00:00:51.211: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:52.207: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.198.0.229 obtained through DHCP
*Mar  1 00:00:52.207: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.198.0.230 obtained through DHCP
*Mar  1 00:00:52.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:52.215: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:00:52.223: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:53.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:53.243: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:54.243: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 16 02:13:35.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:13:37.055: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:13:37.055: %CAPWAP-5-SENDJOIN: sending Join Request to 10.207.15.23
*Sep 16 02:13:37.839: %LWAPP-4-CLIENTEVENTLOG:
Checksum required saved version = 8.0.100.0, file flash:/lwapp_reap.cfg
*Sep 16 02:13:38.951: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 16 02:13:39.875: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 2
*Sep 16 02:13:40.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 16 02:13:40.243: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller XVD-WLC-5508-02
*Sep 16 02:13:40.287: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:13:40.287: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:13:40.287: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration filecapwap_delete_all_l2Acls_in_nacl_list:336. Deleting all L2Acls in AP config
*Sep 16 02:13:41.895: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
Writing out the event log to flash:/event.log ...
*Sep 16 02:20:51.675: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: Recvd RESET req from Controller.
*Sep 16 02:20:51.687: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Write of event.log done
IOS Bootloader - Starting system.
flashfs[0]: 36 files, 3 directories
flashfs[0]: Bytes used: 10009088
flashfs[0]: Bytes available: 21859840
executing...
executing...
           cisco Systems, Inc.
flashfs[2]: 36 files, 3 directories
flashfs[2]: Bytes used: 10009088
flashfs[2]: Bytes available: 21601792
export@cisco.com.
Last reset from unknown reload cause - ptr to non-ascii bytes 0x18
2 802.11 Radios
*Mar  1 00:00:09.747: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:12.411: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:15.455: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:15.467: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:18.087: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:18.087: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:18.463: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:18.531: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:18.735: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:18.739: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:19.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:20.011: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source
*Mar  1 00:00:21.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:30.559: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.199.119.147, mask 255.255.255.192, hostname APb000.b461.a220
*Mar  1 00:00:36.603: Using SHA-1 signed certificate for image signing validation.%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:40.939: AP image integrity check PASSED
*Mar  1 00:00:40.947: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:41.027: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:00:42.127: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:42.135: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:43.127: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:43.235: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:44.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
%Error opening flash:/capwap-saved-config (No such file or directory)
*Mar  1 00:00:51.047: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 CLI Request Triggered
*Mar  1 00:00:51.055: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:51.059: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:56.099: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:56.115: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Mar  1 00:00:56.115: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:57.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Translating "CISCO-CAPWAP-CONTROLLER."...domain server (10.207.15.11)
*Mar  1 00:00:59.831: Starting Ethernet promiscuous mode
*Mar  1 00:00:59.839: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.198.0.229 obtained through DHCP
*Mar  1 00:00:59.839: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.198.0.230 obtained through DHCP
*Mar  1 00:03:15.031: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Mar  1 00:03:15.031: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Mar  1 00:03:15.031: %MESH-6-LINK_UPDOWN: Mesh station b000.b461.a23c link Down
*Mar  1 00:03:34.151: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:03:39.191: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:06:04.151: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Mar  1 00:06:04.151: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Mar  1 00:06:04.151: %MESH-6-LINK_UPDOWN: Mesh station b000.b461.a23c link Down
*Mar  1 00:06:23.271: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:06:28.311: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
flashfs[0]: 35 files, 3 directories
flashfs[0]: Bytes used: 10014208
flashfs[0]: Bytes available: 21854720
executing...
executing...
           cisco Systems, Inc.
flashfs[2]: 35 files, 3 directories
flashfs[2]: Bytes used: 10014208
flashfs[2]: Bytes available: 21596672
export@cisco.com.
2 802.11 Radios
*Mar  1 00:00:08.539: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:09.299: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-6)
*Mar  1 00:00:09.299: Registering HW DTLS
*Mar  1 00:00:09.731: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:11.527: %LINK-6-UPDOWN: Interface Ethernet4, changed state to up
*Mar  1 00:00:12.395: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:12.403: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.403: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:12.403: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:12.403: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:15.263: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:15.451: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:15.519: Starting Ethernet promiscuous mode
*Mar  1 00:00:18.083: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:18.083: %SNMP-5-COLDSTART: SNMP agent on host APb000.b461.a220 is undergoing a cold start
*Mar  1 00:00:18.503: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:18.543: Starting Ethernet promiscuous mode
*Mar  1 00:00:18.707: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:18.707: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:20.311: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
*Mar  1 00:00:36.571: Currently running a Release Image
*Mar  1 00:00:36.583: Using SHA-1 signed certificate for image signing validation.
*Mar  1 00:00:41.003: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 CLI Request Triggered
*Mar  1 00:00:41.011: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:00:41.015: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:42.107: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
Not in Bound state.
*Mar  1 00:00:42.115: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:43.023: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:43.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:43.215: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:44.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:46.043: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.043: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:46.095: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.199.119.147, mask 255.255.255.192, hostname APb000.b461.a220
*Mar  1 00:00:46.095: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.095: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:51.135: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:51.151: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Mar  1 00:00:51.151: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:52.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:55.831: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.207.15.23 obtained through DHCP
*Sep 16 02:30:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:30:49.559: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:30:49.559: %CAPWAP-5-SENDJOIN: sending Join Request to 10.207.15.23
*Sep 16 02:30:50.759: %LWAPP-3-CLIENTERRORLOG: Load Reap Cfg failed, trying backup...
*Sep 16 02:30:50.775: %LWAPP-4-CLIENTEVENTLOG:
*Sep 16 02:30:50.779: %LWAPP-4-CLIENTEVENTLOG: No REAP non-ap specific configuration file to load. Connect to controller to get configuration file
*Sep 16 02:30:52.215: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 16 02:30:52.223: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 16 02:30:52.651: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller XVD-WLC-5508-02
*Sep 16 02:30:52.691: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:30:52.695: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:30:52.695: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:30:52.695: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration filecapwap_delete_all_l2Acls_in_nacl_list:336. Deleting all L2Acls in AP config
*Sep 16 02:30:53.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 16 02:30:53.243: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 16 02:30:53.867: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 2
*Sep 16 02:30:53.867: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 16 02:30:54.127: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Sep 16 02:30:54.871: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 16 02:30:55.895: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 16 02:30:56.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to upRename from flash:/lwapp_reap.cfg to flash:/lwapp_reap.cfg.bak failed, errorno = 2
*Sep 16 02:31:14.119: %CLEANAIR-6-STATE: Slot 1 disabled
*Sep 16 02:38:12.379: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 16 02:38:12.387: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 16 02:38:13.055: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Sep 16 02:38:13.407: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Sep 16 02:38:14.387: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 16 02:38:15.339: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 2
*Sep 16 02:38:24.375: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: Recvd RESET req from Controller.
*Sep 16 02:38:24.387: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
flashfs[0]: 39 files, 3 directories
executing...
executing...
           cisco Systems, Inc.
flashfs[2]: 39 files, 3 directories
export@cisco.com.
2 802.11 Radios
*Mar  1 00:00:08.563: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:09.323: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (1-6)
*Mar  1 00:00:09.323: Registering HW DTLS
*Mar  1 00:00:09.759: m8349_ether_enable: MACCFG1 sync timeout
*Mar  1 00:00:11.559: %LINK-6-UPDOWN: Interface Ethernet4, changed state to up
*Mar  1 00:00:12.423: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:12.435: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.435: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:12.435: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:12.435: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:15.291: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:15.479: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:15.547: Starting Ethernet promiscuous mode
*Mar  1 00:00:18.119: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:18.119: %SNMP-5-COLDSTART: SNMP agent on host RAP is undergoing a cold start
*Mar  1 00:00:19.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:20.035: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source
*Mar  1 00:00:20.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet4, changed state to up
*Mar  1 00:00:21.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:22.163: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:22.203: Starting Ethernet promiscuous mode
*Mar  1 00:00:22.367: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:22.367: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:36.603: Currently running a Release Image
*Mar  1 00:00:36.615: Using SHA-1 signed certificate for image signing validation.
*Mar  1 00:00:41.023: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:00:41.027: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:41.035: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 CLI Request Triggered
*Mar  1 00:00:41.043: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:42.119: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
Not in Bound state.
*Mar  1 00:00:42.127: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:43.035: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:43.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:43.227: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:44.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:46.051: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.051: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:46.107: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.199.119.149, mask 255.255.255.192, hostname RAP
*Mar  1 00:00:46.107: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface BVI1 obtained IP from DHCP...
*Mar  1 00:00:46.107: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:00:51.147: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:00:51.215: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:52.211: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.207.15.23 obtained through DHCP
*Mar  1 00:00:52.215: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:52.219: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:00:52.227: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:53.219: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:53.247: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:54.247: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Sep 16 02:40:24.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:40:24.555: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.207.15.23 peer_port: 5246
*Sep 16 02:40:24.555: %CAPWAP-5-SENDJOIN: sending Join Request to 10.207.15.23
*Sep 16 02:40:24.771: %LWAPP-4-CLIENTEVENTLOG:
*Sep 16 02:40:26.219: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Sep 16 02:40:26.227: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Sep 16 02:40:26.443: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep 16 02:40:26.595: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller XVD-WLC-5508-02
*Sep 16 02:40:26.639: %LWAPP-4-CLIENTEVENTLOG: No Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:40:26.639: %LWAPP-4-CLIENTEVENTLOG: No LS Flex ACL map configuration file to load. Connect to controller to get configuration file
*Sep 16 02:40:26.639: %LWAPP-4-CLIENTEVENTLOG: No Central Dhcp map configuration file to load. Connect to controller to get configuration filecapwap_delete_all_l2Acls_in_nacl_list:336. Deleting all L2Acls in AP config
*Sep 16 02:40:27.219: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
Will
Everyone's tags (1)
Hall of Fame Super Gold
What country code is your WLC
What country code is your WLC?
Australia and the AP seems to
Australia and the AP seems to be in the correct country. The Operational Status is "REG" on both AP's.
911
