Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Re-authenticate wireless user periodically
How could i enforce that the user will be authenticated after every 24 hours if he continuously connected on the wireless device. I have a setup with cisco acs server with standalone 1252 wireless access point and Running PEAP authentication with acs server with WPA2.
Re: Re-authenticate wireless user periodically
There are timers with in the PEAP setup on the ACS server that will force the user to reauthenticate.  The user shouldn't see this even happen if he has cached credentials on his PC but if not he will be prompted at the interval you set in ACS.
Hope this helps.
Adam
In ACS go --> System Configuration --> Global Authentication Setup -->PEAP SESSION TIMEOUT--PEAP SESSION TIMEOUT
PEAP session timeout (minutes)—Enter the amount of time in minutes to  define the length of the maximum PEAP session.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
368
