Reducing Power Transmission on multiple LAP at one time
Hi Cisco Support Community,
I'm trying to modify the power transmission control of multiple Lightweight Access Points (1131 AG E K9) at one single time on WLC 4400 or WCS.
It is effectively possible to configure the power transmission per LAP and in global on WLC 4400 but i need to configure it per group of LAPs =i.e group X of 10 LAPs will have a power Threshold of X -dBm and group Y of 15 LAPs with Y -dBm.
Any help will be much appreciated.
I thank you in advance.
Best Regards,
Pascal.
  • Getting Started with Wireless
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Reducing Power Transmission on multiple LAP at one time
You should be able to create a separate ap template in WCS. One for Group X and another for Group Y. Then you should be able to set the TX power level (not dbm).
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Hall of Fame Super Gold
With 7.2.X, you can create AP Groups and set each AP Group a particular transmission power.
Hi Scott Fella and Leolaohoo, I will give a try and keep you posted.
Thanks for the quick respond.
Best Regards,
Pascal
490
