Remote 5508 Standby Controller HA-SKU
Michael Shelton
How does the standby HA-SKU controller that is located remotely miles away maintains it's heartbeat while serving as backup to multiple sites.
Sent from Cisco Technical Support Android App
5 Replies 5
George Stefanick
Hi Michael,
There are different deployments of HA with the HA-SKU.
1) You have AP-SSO/Client-SSO this is where the controllers are 1 - 1 sync and not 1 to multiple.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/High_Availability_DG.html
2) You have HA N+1 backup. This is where the WLC turned into HA converts to MAX licenses and acts like a fullly licensed controller. You can back up 1 to many in this design.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide/N1_HA_Overview.html
Hope this helps
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
Scott Fella
Just to add... You don't want to do AP SSO over layer 3 unless you are spanning your subnets. What you need to do is N+1 which is what George also posted. There is no heartbeat between the two with N+1 like in AP SSO.
-Scott
I just deployed 5 hospitals with N+1 and it works well ..
Agreed.... it does work well.... compared to AP SSO:)
Sorry Leo... hehe
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Michael Shelton
Thanks Guys I appreciate the information
