Remote Local - wireless solution / VoIP support with satallite Internet
Hello.. Have a nice remote headache..
I have a very remote location with no wired services. I need to provide Internet and likely VoIP. I also have to cover a .5 mile distance between two buildings. Thoughts? Looking at the Aironet 1400 series for the bridge.
  • Getting Started with Wireless
1 REPLY
Re: Remote Local - wireless solution / VoIP support with satalli
If you have line of sight between the buildings, the 1400 will be fine, you can use the cisco bridge calculation utility found here http://www.cisco.com/application/vnd.ms-excel/en/us/guest/products/ps458/c1225/ccmigration_09186a00800a912a.xls, to work out what you need.. if anything the 1400's might be a bit 'overkill' for such a short hop, but will give you a 54mbs link, which will be plenty for VoIP & Internet access.
207
