REPEATER FOR BRIDGE
can a bridge have repeaters like roots AP (350)?
can a root AP have many bridges .?
Re: REPEATER FOR BRIDGE
Hi ,
A) Bridge can be made Access Point but Access Point can not be mad Bridge
B) In case of Access Point , there are two mode , Root and Repeater .
If you put AP in repeater mode , ethernet port is disabled . Repeater is
use to extend the wireless coverage ( or to extend the cell where you don't have wired connection ) .
Disadvantage of puttting AP in repeater mode is throughput reduces but half .
You can have chain of 7 repeater .
Example
Lan ----Ap(root) ---AP(repeater 1) ----Ap ( repeater 2) ---->
If you observer that AP ( root ) is only the AP connected to backbone or wired net .
Now if you can connect wired net to all AP than better to put all AP in root mode
example
Backbone wired net
Ap1(root) Ap2(root) Ap3(root)
NOw , in case of bridge you can convert it in AP mode or repater AP mode .
If you have bridge in AP mode or repeater mode it bahves as above design .
Bridge has other two modes Root Bridge and NON ROOT Bridge .
Design 1 :
Bridge ( Root bridge ) ------RF ------Bridge ( NON ROOT BRIDGE )
Above is very basic design , two bridges , one root and other non root .
depending on distance and antenna you can cover up to 25 miles .
Design 2
Bridge ( Root ) -------Bridge ( Non root ) ---------Bridge ( Non root )
Now if you want to connect bridges in one continous chain than you can put the bridge in non-root ( which is like repater in bridge mode ) .
Now VERY CAREFULL , YOU CAN NOT DO as designed below
Bridge ( root ) -------Bridge ( repeater ) -----Bridge ( Non root )
Above design is wrong and will not work .
If you have hub and spoke you can do like
bridge 1( non root ) --------Bridge ( HUB ) ROOT ------Bridge ( non root )
Or
Bridge ( root ) -----RF ---Bridge ( non root ) --Wired --Bridge ( root ) ----Bridge ( nont root )
Now saying all this you can have
bridge ( root ) --------bridge ( non troot ) ---Lan --AP -----Wireless clients
So can you have
LAN === Bridge (root) <----->200m<----> Bridge (AP mode) <--> Wireless clients
Sure..that design will work..
Bridge ins AP mode can not talk to Bridge in root mode .
You can have
Lan bridge ( root ) -----------Bridge (non root with clients ) --Wireless clients
OR
Lan --bridge ( ap mode )----------Bridge ( repeater mode ) ---Wireless client
380
