Replacement of Antenna
What is the replacement for this kind of antenna AIR-ANT2012 that will work as the same coverage?
Silver
Re: Replacement of Antenna
Hi Rami,
have a look here ans search for your antenna number.
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_eol_notice0900aecd80490c5b.html
Replacement part:
AIR-ANT2465P-R
2.4 GHz, 6.5 dBi Diversity Patch Antenna with RP-TNC Connectors
Hope that helps.
Best regards,
Frank
Please rate helpfull posts.
Yes the problem was solved .
Than you
Rami
143
