Resetting 1242AP to default using the MODE button
I have a couple of remote 1242APs with static IPs that are not responding to pings. I'd like to reset the APs and see if they will pull DHCP addresses. If we reset the APs using the mode button will with wipe out the static IP?
Thanks!
Everyone's tags (1)
Hall of Fame Super Red
Hi Jason,
Yes, the IP will be reset to 10.0.0.1
Cheers!
Rob
Silver
its no, You have to configure from console only
Posted by WebUser Srinivasa Reddy
HI Jason ,
If you use the mode button it will reset the entire configuration and make the AP to Factory default. If you have DHCp enable in your network AP will be taking DHCP IPaddres .
As far as i know the default ip 10.0.0.1 will come only if you are going to the AP rommon mode ( for recovery )
Angus
Please rate the post if its usefull .
1089
