Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
restrict SSID/VLAN to certain AP's ?
Is it possible to restrict SSID/VLANS to certain access points from a 4400 controller ?
If I set up new SSID's they are broadcast from all ap's by default, however I onluy want the SSID's to be used in the areas that match the user type.
How do you do this ?
Nm
1 ACCEPTED SOLUTION
Gold
Re: restrict SSID/VLAN to certain AP's ?
Gold
No......
I have multiple SSID's and a singe site, not singel SSID and geographically diverse which is what the groups config does.
Thats not it at all.
Sorry, you were right.
The technote isn't too clear, but after research and testing, it is the right thing. Thanks for the help.
378
