RMON mode for c1250 AP
   I have one 1252 LAP acces point which went to the RMON mode . I tried to do the following steps to put a new image on the access point with the following steps :
ap: set IP_ADDR 10.88.81.181
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 10.88.81.254
ap: tftp_init
ap: ether_init
ap: flash_init
ap: tar -xtract tftp://10.88.117.61/c1250-k9w8-tar.152-2.JB flash:  ( image will be loaded successfully)
set BOOT flash:/c1250-k9w8-tar.152-2.JB.tar
ap: set
BOOT=flash:/c1250-k9w8-tar.152-2.JB.tar
CRASH_LOG=yes
DEFAULT_ROUTER=10.88.81.254
ENABLE_BREAK=no
IP_ADDR=10.88.81.181
MANUAL_BOOT=no
NETMASK=255.255.255.0
NEW_IMAGE=yes
RELOAD_REASON=23
TERMLINES=0
ap: boot
i am getting the following result after booting
Loading "flash:/c1250-k9w8-tar.152-2.JB.tar"...flash:/c1250-k9w8-tar.152-2.JB.tar: no such file or directory
Error loading "flash:/c1250-k9w8-tar.152-2.JB.tar"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c1250-k9w8-mx.152-2.JB1/c1250-k9w8-xx.152-2.JB1"...Bootable image segment 0 address range [0x3000, 0x10ecc98] not in range [0x3000, 0xe80000].
Error loading "flash:/c1250-k9w8-mx.152-2.JB1/c1250-k9w8-xx.152-2.JB1"
Boot process failed...
Any ideas ?
Hall of Fame Super Silver
Re: RMON mode for c1250 AP
You need to specify the folder and then the file for the boot. When you upload the file, it creates a folder and then the image is located within that folder.
BOOT=flash:/c1250-k9w8-tar.152-2.JB.tar/1250-k9w8-tar.152-2.JB.tar
-Scott
Hi ,
Actually i found the boot command we need to use in this case and my access points boot successfully after this and they are working fine now .
set BOOT flash:/c1250-k9w8-mx.152-2.JB/c1250-k9w8-mx.152-2.JB
I found this mx when the tar image was extracting
Note: When you want to load the image (tar file)you need to use the following
ap: tar -xtract tftp://10.88.117.61/c1250-k9w8-tar.152-2.JB.tar flash:  ( image will be loaded successfully)
Hall of Fame Super Gold
Hold on ... You CANNOT boot a TAR.
You will need to copy the BIN file into the AP.
367
