02-20-2014 08:45 AM - edited 07-05-2021 12:14 AM
hi All,
I have a doubt on how roaming works.
I have AP's and AP Groups
2 WLC
All Access points associated to same WLC
AP Group 1 - Subnet A - VLAN 1
AP Group 2 - Subnet b - vlan 2
Now if a user roams from APGroup 1 --> APG2 , means in diff subnet. What will happen with the user roaming. Whether user is going to get a new IP or going to retain the same because they are in the same WLC.
PLease clarify
02-20-2014 08:52 AM
User will retain their ip address and this is considered layer 3 roaming. This works fine if the AP's are in local mode, but in flexconnect, the user will drop and have to re-associate and get a new ip address.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-20-2014 09:34 AM
so if the access points are associated to same or diff WLC it performs L3 roaming right and at no point user experiences any disruption.
02-20-2014 09:36 AM
As long as the user doens't loose wirless signal, then yes, this is seamless layer 3 roaming. FlexConnect is different though.
Scott
