Roaming wirelessly between Sites
I am planning the design of a wireless network that will span many of our branch offices.
The requirement is a user in Site A can connect to the wireless and switch their traffic locally. Then user moves to Site B and I need that users traffic to switch locally in Site A
I understand this will work if I am running converged access and is called anchoring.
I would need a 3850 at each site to terminate the tunnels and all these switches need to be in a switch peer group, it will all be controlled from the head office with a 5508 as the Mobility controller.
However this would only work if the user did not have to re-authenticate (which could be up to 24 hours?)
Can anyone advise on the best way to achieve this?
Roger
1 REPLY
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-3/configuration/guide/b_cg73/b_wlc-cg_chapter_01111.html
39
