RSSI Signal ranges
I am troubleshooting a problem where just one user
is having a problem.  They intermittently drop their wifi
connection.  If they do a repair, the connection comes back up without a problem.
No other user is having a problem at this location (at least that has been reported to me).
I am getting ready to have them look at upgrading the wireless driver and/or recreating the wireless profile on the machine.
My question is there an explanation of the RSSI signal ranges (i.e. what is bad, good, better, etc) ?  For example, the user that is having a problem is showing a RSSI that is ranging between -74 to -78.    I know that Cisco VOIP phones start having problems at -70.  I have to deal with a regional IT person that I need to present the info to him in this way.
Ron
1 REPLY
Re: RSSI Signal ranges
Hi Ronald,
At -84, you will most likely lose connection completely.
At -80, you can't use all data rates and are probably facing a lot of retransmissions.
At -75, the signal is considered as poor, you might have some retransmissions but you should still have connectivity.
In any case, at around -75, the driver should be thinking about roaming. So it's either a bad driver (not roaming) or there is simply no better AP around.
There is no general values since this differs on all clients, but what I wrote above is a good approximation. Starting -75, the client start to lower data rates.
Best regards,
Nicolas
Please rate answers that you find useful
472
