Set Max power globally
Hello ,
kindly i would like to set the max power of all my access points to be 17 dbm in order to match the clients power to eliminate any possible one-way communication issue .
so does the option in the TPC setting page  :  " max power level assigment (-10 to 30 dbm ) "  work for that ?
also based on cisco , TPC algorithm  triggered under certain conditions like 3 nearby APs detected at -70 dbm and so one , so does it mean , if  thoes conditions do not meet the above max power level value will not be applied ?!!!!
1 ACCEPTED SOLUTION
VIP Purple
Yes, in TPC setting if you
Yes, in TPC setting if you set max to 17dBm, then your AP power max at that level.
Rasika
**** Pls rate all useful responses ****
1 REPLY
VIP Purple
Rasika
34
