Setting a WLAN on 1841W in autonomous mode!
Hi guys
I have a setup where i am installing 1841W router which also has an 4-port ethernet module for wired users.
There are different levels of complexities involved, as of now I will only keep it to 4 points:
1. I need to have just one VLAN on the WLAN (VLAN 320)
2. The users will be required to be authenticated via a NPS server across the WAN
3. The wired users will have two VLANs, Data and Voice (VLAN 240 and 651)
4. All the VLANs will need to go a DHCP servers for ip addresses for the clients.
Based on the above, I have compiled a rough config, wanted to know if I am missing something:
***************************Router********************************
hostname A
no aaa new-model !(I have to configure this bit)
service-module wlan-ap 0 bootimage autonomous
controller Cellular 0/1
interface Loopback0
ip address 128.1.1.1 255.255.255.255
interface Loopback1
ip address 10.51.240.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 1.1.1.1 255.255.255.255
arp timeout 0
no mop enabled
no mop sysid
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
no ip address
interface GigabitEthernet0/0/0
switchport access vlan 240
switchport voice vlan 651
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 !(Assuming 3G service is working)
**********AP CONFIG************
hostname AP1
enable secret 5 $1$nD9N$8fK4tS4Yb8k7rTYyosEU2/
dot11 syslog
dot11 ssid VCORP
   vlan 320
username cisco privilege 15 secret 5 $1$Oc3J$IjBvJw47ZjflC2181on6k0
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid VCORP
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 320 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid VCORP
antenna gain 0
no dfs band block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.51.246.1 255.255.255.0
ip helper-address 10.32.0.155
no ip route-cache
bridge 1 route ip
Any suggestions if I am missing anything, or you think anythiing is wrong? I am not sure whether ip is to be given on the BVI interface or on
G0 or G0.1???
Cheers,
Mohit
VIP Purple
Hi Mohit,
Based on your other post, I think you already got this working.
It should be BVI where you assign IP & not G0 or G0.1
Rasika
**** Pls rate all useful responses ****
Universal Client Mode
Universal client mode is a wireless radio station role that allows the radio to act as a wireless client to another access point or repeater. This feature is exclusive to the integrated radio running in the Cisco 870, 1800, 2800, and 3800 integrated service routers (ISRs).
Universal client mode has the following features and limitations:
•You can configure universal client mode on the main dot11radio interface only, subinterfaces are not supported.
•Universal client can associate to access points with radio VLANs.
•Layer-3 routing is supported over the radio interface. However, there is no support for layer 2 (L2) bridging. The user cannot configure a dot11radio interface with a bridge-group when in universal client mode.
•Service Set Identifiers (SSIDs) are required to be configured on the dot11 interface operating as a universal client; association to an access point running in guest mode is not supported.
•The universal client can associate to Cisco access points, third party access points, and repeaters. It cannot associate to Cisco root bridges or Cisco workgroup bridges.
•Easy VPN does not support universal client mode using DHCP.
Hi guys
The config went ok.
Just a word of caution to people who are doign it for the first time,
the
interface Wlan-GigabitEthernet0/0 config should align with your BVI interface config.
Like in my case I used VLAN 1 on WLAN-G0/0 and the same in the AP config ie  BVI1
I had used a SVI for VLAN 1 on the router with ip in the same subnet as ip on the bvi1 interface.
Rest all smooth!
One more good ISR config example..
http://www.dslreports.com/faq/15257
454
