Setting up a vlan on WLC 2504
jimmyfoddrell
I am setting up a 2504. I would like to set up 1 WLAN to connect directly to an ISP switch to use as a PUBLIC network. I configured port 2 on the 2504, set up interface with an address, then created a WLAN and SSID. (Port 1 is set up as internal and connects to the Catalyst 3850) It seems to work. When I change it to different VLAN ID, it does not work. Although port 2 is directly connected to the ISP device, do I have to make any changes on the catalyst for this to work or am I overlooking something. Thanks.
6 Replies 6
Stephen Rodriguez
What are you changing? The management interface VLAN tag?
Keep in mind that the WLC is a dot1q trunk, so if you set the management interface VLAN tag to the switchports native vlan, traffic will get dropped.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks for the repose. The MI is on port 1. I am wanting to assign it to port 2, which is directly connected to the ISP router.
Why are you wanting your management interface to go to the ISP?
the AP's are on the internal network, and if you put mgmt to ISP, you won't be able to manage the WLC, nor will the AP be able to join.
Steve
HTH,
Steve
Port 1 is my Mgt interface which connects to a cisco 3850. Port 2 goes to the ISP device.
Stephen Rodriguez
Ok, then I'm confused
"When I change it to different VLAN ID, it does not work
What doesn't work? what VLAN are your changing and where?
Steveß
HTH,
Steve
abwahid
Level 4
Level 4
Go on below link, it possibly will be helpful for you.
https://supportforums.cisco.com/discussion/11585281/2504-wlc-and-2-vlans
