04-10-2003 07:13 AM - edited 07-04-2021 08:38 AM
Does anyone have any updated documentation/reference on setting up leap on an "ap 1200" with acs?
Adapter and AP works fine with Wep enabled, however when enabling LEAP I am unable to associate. Can't find diagnostics or logging to determine if problem is at acs server or access point or adapter. Thanks in advance
-Eric
Solved! Go to Solution.
04-10-2003 07:20 PM
Hi ,
a) on ap1200 on console you can run
:eap_diag1_on
:eap_diag2_on
to turn off
:eap_diag1_off
:eap_diag2_off
b)
Please make sure that on ap1200 setup-> security you have checked
open and network eap .
Configure 128 bit wep key in slot 1 ( Bkey )
c)
Configure Access Point to point to ACS for authentication. Using the GUI browse to Setup->Security and Select Authentication server
option.
Enter the IP address of the radius server and the secret key.
On the ACS , make sure you configure AP as client . and select raidus Cisco Aironet
Make sure authe port an shared secret matches on AP and on ACS .
d) you can enable full log on ACS and troubleshoot .
Debug information:
This sample debug information is captured at max. logging level of ACS. (ACS GUI->System
Configuratoin->Logging->Level of detail full.
This is csradius log file. Fore more information on ACS debug information, please refer to
http://www.cisco.com/warp/customer/480/9.html
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_white_paper09186a00800b3d27.shtml
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch8.htm
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_white_paper09186a00800b469f.shtml
Note :
Wrong ACS address in AP:
If you have entered wrong IP address of ACS you will see in AP
No EAP-Authentication response for station XXXXXXXX from server 172.17.241.43
Make sure you are running latest firmware and driver on Ap and on client side .
Nilesh
04-10-2003 07:20 PM
Hi ,
:eap_diag1_on
:eap_diag2_on
to turn off
:eap_diag1_off
:eap_diag2_off
b)
c)
option.
Debug information:
Note :
Nilesh
