Setting up Wireless Security
Hello
Right I have a 2811 router with a wireless interface card (dot11radio), I have it setup and I can ping it, surf the internet its all singing and dancing.
Need to know how to enable WPA because at the moment any tom dic or harry can log on!!
I have tried to use the SDM v2.5 however when Im in the SDM and select Tools>>Wireless Application.... it just comes up with this warning message: "The wireless application is not installed on the router. Please select the Update feature from the tools menu to copy the wireless application to your routers flash"
FYI im running the SDM from my PC not the router so dont know why its saying the that. So I then go to Tools>>Update SDM>>Cisco.com and a CCO login is required.
Whats a CCO login , is that just the same login I use for this forum? If so it not working.
Was only using the SDM because I wanted to see the preview commands, if anyone could provide the CLI to enable WPA2 that would also be great...
Anyway thats where im at... a wireless connection that the whole street can use
Thanks for looking
PASSED CCENT  14/08/2013
     BOOKED ICND 2  11/09/2013
back to school!!
Hall of Fame Super Silver
Re: Setting up Wireless Security
CCO is the same login as what you would use on the forum. Access to software depends on your smartnet contract for a product. If your looking for a cli guide to setup wpa2, here you go. The hardware has to support wpa2 though or else you will only be able to use wpa. You will find this out if you don't have v2 option.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
-Scott
Thanks for your reply
I have entered my CCO and its not allowing me to login, assume this is because I dont have a service contract.
back to school!!
That is correct.
-Scott
Scott I think the link you have posted is the GUI and I dont have access to it, could you point me in the right direction for the CLI way.....Thanks
Below is my current config
Core2811#sh run
Building configuration...
Current configuration : 5094 bytes
! Last configuration change at 20:03:14 UTC Sat Aug 17 2013 by James
version 15.0
service password-encryption
hostname Core2811
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
dot11 ssid ADMIN
authentication open
guest-mode
infrastructure-ssid
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.19
ip dhcp excluded-address 192.168.1.61 192.168.1.254
ip dhcp excluded-address 172.0.0.1 172.0.0.10
ip dhcp pool LAN_Addresses
   import all
   network 192.168.1.0 255.255.255.0
   domain-name home.local
   dns-server 8.8.8.8 4.2.2.2
   default-router 192.168.1.1
   lease 0 5
ip dhcp pool Admin
   import all
   network 172.0.0.0 255.255.255.0
   default-router 172.0.0.2
   lease 0 5
no ip domain lookup
ip domain name firewire2013
ip name-server 4.2.2.2
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-4097922664
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4097922664
revocation-check none
rsakeypair TP-self-signed-4097922664
crypto pki certificate chain TP-self-signed-4097922664
certificate self-signed 01
  3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303937 39323236 3634301E 170D3133 30383132 31383537
  31325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30393739
  32323636 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BD0C 248993EC F679FDBC FC5FD5D2 99C93260 63561AAC 11E852C4 F3E78DC9
  B2A5AFD8 4D613995 B9C75F39 7890D109 F12CA393 4EEECCD7 78D2B5DF 1A29A866
  D89A8B0A AA01E86B 5DB1AEF9 5DDC3CC7 ADF66DB0 FC5D50F9 449D4022 7DC81298
  243B1A74 C36907BE C7219EE1 4B7AA6BF D6724AAD B8191CDD 95FB5098 5F0FD131
  BD850203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
  551D1104 19301782 15436F72 65323831 312E6669 72657769 72653230 3133301F
  0603551D 23041830 16801494 220B7E31 D71477E9 0654A5CA C196C2F2 A48E1130
  1D060355 1D0E0416 04149422 0B7E31D7 1477E906 54A5CAC1 96C2F2A4 8E11300D
  06092A86 4886F70D 01010405 00038181 0076A68E A78A0A54 673CA025 1AF285E0
  C0002328 9119922B 1ED2A580 A27CCB23 53A44EBC 17D90C4A 7D6720D0 D388FB60
  04ECE5FF 75E9FC17 E8B78DFF 0090144E 7CA03AB1 DDE305D1 968A028B 598F4F93
  3C270F65 C2DBB0FC BC099CD8 D82E13D8 8AC97E87 B5D74906 B4FDB8D9 1A36F0A6
  340D1F4C 36EC717A 7B3F55AA B208A4A0 7F
        quit
license udi pid CISCO2811 sn FCZ115070AD
username James privilege 15 secret 5 $1$zx1q$a75rtd8krCJRVIpsUFcfx.
redundancy
interface FastEthernet0/0
description Connection WAN INTERNET
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface FastEthernet0/1
description CONNECTION 3550 SWITCH 3
ip address 192.168.100.1 255.255.255.0
duplex full
speed 100
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Dot11Radio0/3/0
ip address 172.0.0.2 255.255.255.0
ip nat inside
shutdown
ssid ADMIN
speed basic-54.0
station-role root
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
interface Vlan1
description Connection to LAN Devices
ip nat inside
interface Vlan2
no ip address
shutdown
router rip
version 2
redistribute static
network 192.168.1.0
network 192.168.100.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source list 2 interface FastEthernet0/0 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 172.0.0.0 0.0.0.255
control-plane
alias exec s show ip interface brief
banner motd ^CCC
###DO NOT LOG ON AUTHORIZED PERSONNEL ONLY####
^C
line con 0
exec-timeout 30 0
password 7 0822455D0A16
logging synchronous
login
line aux 0
exec-timeout 30 0
logging synchronous
login
line vty 0 4
exec-timeout 30 0
privilege level 15
password 7 01100F175804
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
CCENT
back to school!!
Here is another link
http://networking-newbie.blogspot.com/2008/11/configuring-wpa-and-wpa2-on-cisco.html?m=1
-Scott
I have done it....... YAY!!!!
This worked for me
dot11 ssid
    authentication open
    authentication key-management wpa
    guest-mode
    infrastructure-ssid
    wpa-psk ascii 0
encryption mode ciphers tkip
ssid
James
back to school!!
280
