setting wireless vlan by radius
Hi all,
one of our customers would want to assign the vlan that one is put after authentication, in a centralized way using a radius server (radiator).
The leap protocol is working well, but the radius doesn't seem to pass the attributes for the vlan setting to the AP 1100 we're using.
The configuration of the AP is
AP251-Piano1_1#sh ver
IOS (tm) C1100 Software (C1100-K9W7-M), Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
AP251-Piano1_1 uptime is 23 hours, 35 minutes
System image file is "flash:/c1100-k9w7-mx.122-8.JA/c1100-k9w7-mx.122-8.JA"
Product/Model Number : AIR-AP1120B-E-K9
Configuration register is 0xF
AP251-Piano1_1#sh run
Building configuration...
Current configuration : 2932 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname AP251-Piano1_1
aaa new-model
aaa group server radius RADIUS
server 150.1.244.71 auth-port 1812 acct-port 1813
aaa authentication login RADIUS group radius
aaa accounting update periodic 5
aaa accounting network RADIUS start-stop group radius
aaa session-id common
enable secret <snip>
enable password <snip>
ip subnet-zero
dot11 holdoff-time 5
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit <snip> transmit-key
encryption vlan 151 mode wep mandatory
encryption vlan 150 mode wep mandatory
broadcast-key change 300
ssid uni150
vlan 150
authentication open eap RADIUS
infrastructure-ssid
ssid uni151
vlan 151
authentication network-eap RADIUS
accounting RADIUS
speed basic-1.0 2.0 5.5 11.0
rts threshold 2312
station-role root fallback repeater
no cdp enable
dot1x reauth-period server
interface Dot11Radio0.150
encapsulation dot1Q 150 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.151
encapsulation dot1Q 151
no ip route-cache
no cdp enable
bridge-group 151
bridge-group 151 subscriber-loop-control
bridge-group 151 block-unknown-source
no bridge-group 151 source-learning
no bridge-group 151 unicast-flooding
bridge-group 151 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.150
no ip route-cache
bridge-group 1
interface FastEthernet0.151
no ip route-cache
bridge-group 151
interface BVI1
ip address 172.16.150.251 255.255.255.0
no ip route-cache
ip default-gateway 172.16.150.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory
/1100
ip radius source-interface BVI1
snmp-server community eolo RO
radius-server host 150.1.244.71 auth-port 1812 acct-port 1813 non-standard
radius-server retransmit 10
radius-server timeout 20
radius-server deadtime 1
radius-server attribute 32 include-in-access-req format %h
radius-server key xxxxx
radius-server vsa send accounting
radius-server vsa send authentication
bridge 1 route ip
While the radiator users configuration is :
#LEAP
pippo Password="xxxx"
Tunnel-Type= VLAN,
Tunnel-Medium-Type= 802,
Tunnel-Private-Group-ID = "150",
cisco-avpair = "ssid=uni151"
Have anyone already encountered the same problem?
Some hint?
TIA.
Re: setting wireless vlan by radius
Isn't the VLAN assignment tied to the SSID?
On IAS I had to use 10031 for vlan 31......
Maybe you can change the Tunnel-Private-Group-ID to 10150 and see ifthat works....
Don Hickey
245
