Community Member
Several SSIDs can not be broadcast AP 1242
I have tried to configured an AP 1242 Version 12.3(8)JEA2 with 3 SSIDs  , every SSID assigned to a VLAN, but I haven't been able to broadcast the 3 SSIDs at the same time. If I broadcast one the others are not broadcast; several times the following  message  appears "SSID vlanX replace SSID vlanx
as the broadcast SSID.
How can I solve this issue???
regards
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Several SSIDs can not be broadcast AP 1242
Try to use this command under the dot11 ssid:
mbssid guest-mode
-Scott
mbssid guest-mode
-Scott
Community Member
Hi Scott,
Thanks a lot for your suggestion,
You are right !!
in addition to the mbssid guest-mode commmand under dot11 ssid, I have to set mbssid under interface dot11.
Glad you got it working.
-Scott
419
