You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
sh controllers dot11Radio 1 | i Gain
What means each of parameters in an output of command 'sh controllers dot11Radio 1 | i Gain' on Cisco AIR AP1142N-R?
AP1-1#sh controllers dot11Radio 1 | i Gain
Antenna: internal, Gain: Allowed 8, Reported 0, In Use 8
AP1-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
AP1-1(config)#int do
AP1-1(config)#int dot11Radio 1
AP1-1(config-if)#ante
AP1-1(config-if)#antenna gain 6
AP1-1(config-if)#end
AP1-1#
Antenna: internal, Gain: Allowed 8, Reported 0, Configured 12, In Use 8
AP1-1#
AP1-1#conf t
AP1-1(config-if)#no antenna gain 6
AP1-1#conf t
AP1-1#
  • Getting Started with Wireless
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: sh controllers dot11Radio 1 | i Gain
Yes... Internal antennas have a set gain and antenna pattern. The antenna gain command does not affect the radios. It is used for information only if using WLSE/WCS/NCS or Prime.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
The gain is basically for the antenna used on the access point. An 1142 has built-in antennas so this command will not change anything. On access points that have external antennas, you can change the gain to what the gain of the antenna is rated for. This changes the total EIRP of the AP.
Hi, Scott
Ok, rather internal antennas clearly, but what "In Use 8" means? Does it means, that internal antenna have preconfigured Antenna gain (by default) and the Direction pattern has a little changed form?
400
