Should my VLAN interface be UP UP ??
My 871W config is below then the output of the command "show ip int brief". I can get a wireless client to authinticate ok but the client will not pick up an IP address form DHCP?
How do I get my VLAN 1 interface into an UP UP state?
Help!
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
dot11 ssid wlan
vlan 1
authentication open
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.123.1
ip dhcp excluded-address 192.168.123.2
ip dhcp excluded-address 192.168.123.1 192.168.123.10
ip dhcp excluded-address 10.10.10.1
ip dhcp pool LAN-POOL
import all
network 192.168.123.0 255.255.255.0
default-router 192.168.123.1
ip dhcp pool wireless-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
lease 0 2
username xxxxx privilege 15 secret 5 xxxxxxxxx.
archive
log config
hidekeys
bridge irb
interface FastEthernet0
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$
ip address dhcp
ip access-group 199 in
ip nat outside
ip virtual-reassembly
zone-member security out-zone
shutdown
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 key 1 size 128bit xxx transmit-key
encryption vlan 1 mode wep mandatory
ssid wlan
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description Internal-LAN
no ip address
ip nat inside
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan2
ip address 192.168.123.1 255.255.255.0
interface BVI1
ip address 10.10.10.1 255.255.255.0
ip forward-protocol nd
yourname#sh ip int brie
FastEthernet0 unassigned YES unset up down
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES NVRAM administratively down down
Dot11Radio0 unassigned YES NVRAM up up
Dot11Radio0.1 unassigned YES unset up up
Vlan1 unassigned YES NVRAM up down
NVI0 unassigned YES unset administratively down down
Vlan2 192.168.123.1 YES NVRAM up up
BVI1 10.10.10.1 YES NVRAM up up
Hall of Fame Super Silver
Re: Should my VLAN interface be UP UP ??
If you don't have anything active on vlan 1 then it will show down. Take a look at this link. It has a cool spreadsheet:
http://articles.techrepublic.com.com/5100-10878_11-6112367.html?tag=nl.e138
-Scott
Hi!
Seems to be an issue with WEP key.
Please remove the wep key and mode from dot11radio0 and then try.
There is no IP address on VLAN1. Thus, line protocol would stay down. (Up down). VLAN 1 is mapped to bridge-group 1, so BVI1 is the inside interface.
Also, please remove ip nat inside from vlan 1, and put this under BVI1.
-Jai
Stil not UP UP??
Wouldnt the dot11radio0.1 be in VLAN 1 and bring the VLAN interface up?
bridge irb
ip address dhcp
--More-- ip nat outside
shutdown
duplex auto
speed auto
no ip address
ssid wlan
station-role root
no cdp enable
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface Vlan2
interface BVI1
ip nat inside
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.123.2 3389 interface FastEthernet4 3389
ip nat inside source list 1 interface FastEthernet4 overload
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
--More--
yourname#
Dot11Radio0 unassigned YES manual up up
Vlan1 unassigned YES manual up down
BVI1 10.10.10.1 YES manual up up
Yes, dot11radio0.1 belongs to VLAN 1, which is up/up. This pasted configuration seems fine to me.
not able to see bridging commands:
thus, please make sure you have follwoing commands on the router:
bridge 1 protocol ieee
bridge 1 route ip
-Jai
Tried that suggestion and still not UP UP.
Could be a code issue? Ill down grade the code to an earlier release and see if it works then.
Thanks for the replies.
361
