Community Member
Signal Strenght
hello everybaody,
im have tested several antennas for our WLAN, but I dont know which value is needed, that the WLAN does work?!?!
Im remebering, that a value over -65 dBm is good enough to have solid network?! Is this right.
If anyone has an link or something like that, i would be happy.
regards
Re: Signal Strenght
Rocco,
     Check this previous article and see if it helps answer your question.
https://supportforums.cisco.com/message/3145716#3145716
Hope this helps.. Please rate useful posts.
Kayle
Community Member
Re: Signal Strenght
thank you
but from where did you get this information?
especially the information, that you have to have a strengh of -65 dBm for voice networks and -80 dBm for Data networks?
does there exists any books or scripts? Because i have to write a record and therefore i need the source of that information?
I hope you understand what i mean?
Hall of Fame Super Red
Re: Signal Strenght
Hi Rocco,
Great answer Kayle (+5 my friend!)
I also really thought the thread below offered some excellent explanations;
https://supportforums.cisco.com/message/1315824#1315824
Cheers!
Rob
Community Member
Re: Signal Strenght
yes of couse the answer is great, thats what i m looking for
but i cant qoute a forum in my record!
so my consecutive question was where this information cames from?
does there exists a formal description from cisco or so?
Re: Signal Strenght
Rocco,
     Most of it came from years of experience and the rest came from various cisco and airmagnet documents. Your best option if your looking to quote something then check out the Cisco desgin guides.
www.cisco.com/en/US/partner/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch8.html
www.cisco.com/en/US/partner/products/hw/wireless/ps4555/products_implementation_design_guides_list.html
Try those.
Re: Signal Strenght
Hi Rocco,
Here is the Design Guide (with recomendations)
http://www1.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob41dg/ch3_WLAN.html#wp1000268
Cheers!
Rob
1232
