signal strength power and dbm
I have a question about the signal strength power receive by a device.
For exemple, an AP is configured to send the signal with a strengh of 50mw (17dbm). One device receives this signal at -50dbm (0.00001mw).
I would like to understand if it means that the device receive the signal at 0.00001mw or receive a signal 100000 times less powerful than the original signal (50mw). In this case it means the device receive the signal at 0.005mw.
Please could you help me to understand.
Thibault
1 ACCEPTED SOLUTION
VIP Purple
dBm scale is not a linear (it is logrithmic), so if you reduce the power level to half, dBm value won't go down by half.
Power (in dB) = 10 * log10 [signal/reference], if reference is 1mW, then it is in dBm
Using the above you can determine, power level increase/decrease by factor of 2 will become +/- 3dB. Also power level increase/decrease by 10 fold, will become +/- 10dB. Silimlary 100 times become +/- 20 dB & so on.
Therefore 50mW=17dBm, 25mw=14dBm, 12.5mW = 11dBm,...1 mW= 1dBm, 0.5mW= -3dBm....0.00001mW = -50dBm
In your case, receive signal is (50/0.00001) 5,000,000 times less powerful mean 67dB difference to the original signal,  (which is equivlant to -50dBm)
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Thanks a lot for your reply.
Thib
705
