Simple wireless reporting tool for AP1041
We have several Libraries that are using a single Cisco 1041 access point for their wireless network. The library staff has a need to create a monthly report for the Board of Directors that shows how many people used their wiireless network. Just wanted to know if anyone has been able to generate such a report? I know there is syslog server software out there, but do not know if you could summarize the data in such a way that it would give you a wireless user total. I called Cisco and they suggest using the Cisco Prime Network Control but I beleive that to be way to costly for a Library's budget.
Everyone's tags (4)
1 REPLY
Hall of Fame Super Gold
Unfortunately only the WCS/NCS can generate reports of what you are asking.
Another method is using SNMP programming to determine the amount of users.  This will take more time and more knowledge about SNMP programming.
451
