Single SSID - two acls
Hey guys,
I have a question here.  I am setting up a Cisco 5508 wireless controller and was looking for some feedback or assistance.  Basically I already have my guest SSID configured and functioning.  Created an interface group containing my vlans and applied the created ACL "Guest Policy - internet only", which is also working.
I want to setup a second SSID called "staffstudent" and use RADIUS for authentication.  I have already created two separate network policies on the radius server: staff and student.  Each only allows certain user groups.  I want to be able to differentiate on the controller side which profile they are logging in on and then apply the correct ACL.  I have two currently configured:  one for staff and one for student.  It appears to me that since you have to apply the ACL at the interface level I cannot use both since my interface is accepting both staff and students.
Is there a way I can filter them using RADIUS so that when they login RADIUS can return a "student" value and then apply the correct ACL?  Same for staff?
  • Getting Started with Wireless
Everyone's tags (5)
You can use AAA Override in the WLAN and have the ACL applied per user.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00808b041e.shtml
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
That does seem to be what I am looking for but I am using the windows 2008 NPS instead of Cisco.  Any idea of what attribute I should be sending with my two configured groups from the NPS?
309
