Community Member
Site Survey Client on AP 1200
Is there any detailed documentation on the Site Survey Client mode on the AP 1200?
When using this mode I cannot see any indication that it has associated withthe root AP. I would like to be able to pass traffic from the ethernet port to the root AP VIA the AP in client mode. The Ap in client mode shows the radio in blocking when in client mode, is this normal? Is there a way to manually change this to forwarding mode?
Any suggestions would be helpful.
Dave
Re: Site Survey Client on AP 1200
In order to connect the two AP's togather, you need to have one AP as root and other as "Repeater". AP in a Client/Non-root mode is used for diagnostics or site surveys, such as when you need to test the radio by having it communicate with another access point or bridge without accepting associations from client devices.
Here is the docs for that
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgch3.htm#67157
So you need to configure one AP as root and other as Repeater for connectivity over the wireless link.
Community Member
Thanks for the info. I have been to the documentation that you provided a link to. I found in a bit light on details. From what I understand, in repeater mode the traffic that the AP receives on the radio will not be forwarded to the Ethernet port, which is what I'm trying to do.
Essentially, I'm trying to use one radio on this AP as a wireless bridge between two wired networks.
-Dave
By design the eth port of repeater will be disabled so it will not work the way you want.
Community Member
Please go through the attached doc.
260
