03-04-2014 09:53 AM - edited 07-05-2021 12:20 AM
I need to survey a new building for wireless. Actually it's an old nursing home.
In the old days I would setup an IOS AP as a DHCP server on a telescoping pole mounted to a cart.
Can I convert an AIR-LAP to IOS and do something similar?
How do you all do surveys for LWAPs?
Thanks!
Solved! Go to Solution.
03-04-2014 10:00 AM
Yes you can convert the AP to lightweight and vice versa:
Using a TFTP Server to Return to a Previous Release
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
03-04-2014 10:00 AM
Scott
03-04-2014 10:03 AM
Great! Thanks!
I know I can go from IOS to LWAP but I wasn't sure if there is a restriction on converting an AP purchased as LAP to IOS.
03-04-2014 10:11 AM
There is not... I do this all the time and your good:) Just make sure you can download the code.
Scott
03-04-2014 10:16 AM
Is this valid for a CAP-3602i as well?
03-04-2014 10:19 AM
yes autnonomous image for 3602 is there :
more info:
http://ciscotophat.wordpress.com/2013/01/05/configuring-a-3602-for-wireless-surveying/
03-04-2014 10:31 AM
You just need to make sure your CCO has entitlement to download the image... you should be able to keep both image on the AP and then just switch the boot parameter of the AP.
Scott
