04-19-2018 06:13 AM - edited 07-05-2021 08:32 AM
Hi experts,
We are new to cisco. We are using wlc 2504 and air cap 1702. According to the data sheet the max rate that can be supported in 5 ghz is 867 mbps but we are getting max of 150 mbps. Please suggest what we need to check or configure. Thanks.
04-19-2018 06:16 AM
You need to check you client adapter.
To get higher speed you need your adapter to support 3 spatial stream, which is very uncommon.
-If I helped you somehow, please, rate it as useful.-
04-19-2018 01:38 PM
04-20-2018 04:41 AM
