Square Footage Range for AIR-AP1131AG ?
Can someone tell me the indoor square footage range for a Cisco AIR-AP1131AG ? I have someone that is purchasing this unit and wants to cover 3,500 square feet with just one access point. Thanks.
Silver
Re: Square Footage Range for AIR-AP1131AG ?
The range should be fine for that area of coverage. The 1131AG is comparable to the Cisco 4941 antenna, which Cisco says has a range of 300ft at 6Mbps. You'll need to keep several other things in mind, though.
1. Client Capacity - the 1131AG can't support much more than 20 or 25 clients.
2. RF Shadows - An open environment is one thing, but if you have anything in that room then there will be large coverage holes if only a single AP is used. This is especially true with anything metallic.
3. Redundancy - If any wireless traffic is mission-critical, you should probably install a second AP in case the first one fails.
In the end, I would recommend at least one more AP, but purchasing one and trying it out isn't a terrible idea if money is a concern.
Jeff
Hall of Fame Super Gold
I agree with Jeff.
Have "someone" look at this link:
Cisco Aironet Antennas and Accessories Reference Guide
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
Scroll down to the "Cisco Aironet 1130 Series Integrated Antenna" to see a good picture what this unit can/can't do.
Hope this helps.
714
