Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
ssid broadcast
hi All,
I am having some trouble getting the ssid to broad cast.  Below is my config.  Is this the correct way to do it?
dot11 ssid conferenceroom
   information-element ssidl advertisement
interface Dot11Radio0
no ip address
no ip route-cache
ssid conferenceroom
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
thanks in advance!
1 ACCEPTED SOLUTION
Re: ssid broadcast
The config is really the most simple you can get ...
Are you having old drivers on the HP ?
My last wild guess is that if you have a european AP, it could be on channel 13 while the clients don't support that channel because their chip is US-based.
Try setting the channel manually under the radio interface ("channel x" command).
Nicolas
Hall of Fame Super Gold
Re: ssid broadcast
  mbssid guest-mode
mbssid
Re: ssid broadcast
hi leolaohoo,
Here are the results,
ap.yourdomain.com.(config)#dot11 ssid conferenceroom
ap.yourdomain.com.(config-ssid)#mb
ap.yourdomain.com.(config-ssid)#mbssid gu
ap.yourdomain.com.(config-ssid)#mbssid guest-mode
*Jun  3 18:48:06.643: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun  3 18:48:06.655: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
ap.yourdomain.com.(config-ssid)#exit
ap.yourdomain.com.(config)#int dot110
ap.yourdomain.com.(config-if)#mb
ap.yourdomain.com.(config-if)#mbssid
*Jun  3 18:48:20.843: %DOT11-4-NO_MBSSID_VLAN: No VLANs configured in MBSSID mode. Dot11Radio0 not started
*Jun  3 18:48:20.847: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jun  3 18:48:21.847: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
Do I have to enable a vlan?  I only want to have one ssid.
Re: ssid broadcast
the command leolahoo gave was for the case when you have several vlans.
Just forget his 2 commands (remove them) and put "guest-mode" in the dot11 ssid config (instead of mbssid guest-mode).
That will work like a charm ;-)
Nicolas
Don't forget to rate answers that you find useful
Re: ssid broadcast
Here is the config.  But it still isn't working.  What is strange is that I can see an ssid with the mac address of my dot11radio 0 interface with the password I had once set for wpa2.  I have unplugged and replugged the power supply to do a reset, but still same  thing.
   guest-mode
no ip address
no ip route-cache
ssid conferenceroom
antenna gain 0
station-role root
bridge-group 1
Here is the full config,
ap.yourdomain.com.#sho run
Building configuration...
Current configuration : 3101 bytes
version 12.4
no service pad
hostname ap.yourdomain.com.
no aaa new-model
dot11 syslog
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid conferenceroom
antenna gain 0
station-role root
bridge-group 1
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
transport input ssh
cns dhcp
end
ap.yourdomain.com.#
Re: ssid broadcast
   guest-mode
Add" authentication open" to the dot11 ssid configuration.
It should be ok then.
Nicolas
Re: ssid broadcast
hi, Thanks for your answer.  I am still not quite there yet.  I am using 4 laptops for testing, 2 dell laptops and 2 hp.  Everything works fine on the dell laptops, but not on the hp.  I have an air1232ag, the ssid setup on the 1232ag is seen by all the laptops.
the config on the air 1232 is
dot11 ssid surferrosa
   authentication open
   guest-mode
no ip address
no ip route-cache
ssid surferrosa
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
Re: ssid broadcast
Nicolas
Re: ssid broadcast
bingo!  I set it to channel 1 and I can see the ssid. Thanks for you help!   You are the man!
What is the best channel so that I won't have any issues with laptops from different countries?
Re: ssid broadcast
1, 6 and 11 are the super standards channels. Pick any of the 3 depending on your surroundings (you might have neighbors on 6 and 11 or on all 3, we can't know).
I'm glad I could help. I've already pulled some hair having the same problem before realizing the AP was sitting on channel 13.
Nicolas
Re: ssid broadcast
MBSSID is only if you want to have multiple SSIDs broadcasting on the same AP.
this Implies having multiple VLANs configured and that is why you got that message when adding  the command on the radio.
If you have a single SSID that you want to broadcast you can simply do:
ap.yourdomain.com.(config-ssid)#guest-mode
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
1032
